Samsung LN32A330J1D Image Problem
Samsung LN32A330J1D, have distorted image, bad quality, video noise, tried coaxial and HDMI input (same issue), but the on screen menu display looks ok. What could be the issue?
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
SOURCE: Vizio VX32L image distorts on edges like looking in a metal bowl.
I had a similar issue. Realized that the TV's "WIDE" setting was changed from "Wide" to "Panaramic". It was this panaramic setting that was causing the distortion on both sides of the screen. I had to switch it back to "Wide" using the "Wide" button on the remote to toggle back to "Wide" setting. Once I put it back to "Wide", problem went away. Hope this helps.
Posted on Mar 05, 2009
jomabug76
  • 1148 Answers
SOURCE: Samsung 47" HD Projection TV with color distortion
COLOR CONVERGENCE IN THE MENU
Posted on May 15, 2009
SOURCE: Powers on but no video display
I think I have a similar problem. The screen lights up, but I have thin vertical lines, mostly washout out by white toward the top. However, I can hear the TV programs even as I surf up and down through my channels.. If I change inputs, it seems to cycle through each mode, and I am able to get back to the TV input, but the display does not change.
Posted on Jun 22, 2009
techman
  • 3130 Answers
SOURCE: Distorted image and color separation and overlap
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Posted on Jul 06, 2009
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    I have a samsung ln40d630m3f sound but no picture. Any ideas?
    HDMI or? Depending on what input your using i would say check and even swap the cables. I had a few come through for repair that ended up just being bad HDMI cables that were passing audio but not video.
    If thats not it, and none of the inputs work, also try going to the antenna or cable input if your not using those even if nothing is connected to the coaxial input just to see if you can get snow or a blue screen saying no signal, then i would suspect you have another failure inside. Could be a power supply issue but that generally affects video and sound, could be a bad backlight inverter, the picture is actually there but you can't see it. Try a really bright flashlight, get up close and shine it on the screen at an angle and see if you can see a picture there thats just really dark. Sometimes the backlight inverter fails and the tv is working fine otherwise.
    Nov 25, 2015 | Samsung Televison & Video
    How do I find the right channel to set my tv on so it will receive cable tv
    If it is a cable box and you are connecting via coaxial cable using the rf converter in the box it is usually channel 3-4 but it can often be switched. If it is a satellite box it may use a high channel number like 73. Keep in mind that there is a traditional tuner and a digital tuner in your tv set so you made need to connect the cable and then do a channel setup for it to sense the active channel.
    The image quality is best when the cable box is connected in this order from poorest to best; coaxial cable, rca cables (red,white,yellow), s-video (on older televisions), component video and optical audio using the three yellow, blue, green cables for video and a white or red for audio or optical input, DVI, or the best, HDMI with support for 1080p and audio. On your TV you should use an HDMI cable and simply change the Input or source button to that. The HDMI cable integrates video and sound and it will transmit a dolby surround signal to your TV just as a separate optical connection will.
    Nov 27, 2013 | Insignia 42" LCD Flat-Panel HDTV
    Flatron m2362d
    Hello
    Researching your monitor specifications, it has a native resolution of 1920x1080 so the setting you are running should work.
    Have you tried the other HDMI port on the monitor? It has to inputs and it is possible that the current port is causing the reported issue.
    Another option is to get a DVI to HDMI adapter OR use a DVI cable with your graphics card to see if that corrects the issue. It is possible that the HDMI inputs are going bad and using a different input could resolve the issue. Both DVI and HDMI are digital inputs so you should not see any quality differences between the two connections.
    The final check would be to connect your PC to another HDMI enabled screen (another monitor or TV) and see if the resetting continues on a different screen. If the problem occurs on a different display, you will likely have to download and install the latest video drivers for your card.
    Hope this helps.
    Nov 09, 2013 | Computers & Internet
    VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
    turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
    May 10, 2013 | Vizio VX37L Television
    Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
    Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
    Look at the connectors on the back of your TV. You could have:
    * coaxial input (lowest video-quality)
    * S-Video input (better video-quality)
    * component input - three cables for video, two cables for audio (better video-quality)
    * HDMI input (highest video-quality)
    Look at the connectors on the "output" side of the PVR. You could have:
    * coaxial output (lowest video-quality)
    * S-Video output (better video-quality)
    * component output - three cables for video, two cables for audio (better video-quality)
    * HDMI output (highest video-quality)
    Connect the "outputs" to the "inputs", using appropriate cables.
    Turn the PVR on. Turn the TV on.
    Use the "source" button on the TV's remote-control to select from the various inputs
    (Coax, S-Video, Component, HDMI1, HDMI2).
    If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
    Feb 03, 2011 | Computers & Internet
    How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
    hi,
    do the following.
    1. connect ur blue rays hdmi out to ur tvs hdmi input.
    2. connct blue rays out to any one of the coaxial(aux) input of bose.
    3. connect ur tvs optical audio output to optical audio input of bose
    4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
    4 . in the blue rays audio setup select audio output priority as optical/coaxial
    5 . in bose set aux as digital input.
    to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
    to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
    to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
    ok
    Dec 15, 2010 | Televison & Video
    Bad image quality with HDMI connexion
    Try a different HDMI cable. Check the on screen menu when this happens to see if it looks normal.
    Cheers
    Dec 29, 2009 | Televison & Video
    Wavy Video output from Marantz sr5600 Receiver
    are you using component inputs s video rbg or hdmi?
    Jan 31, 2009 | Marantz VP15S1 Television
    Logiteck quickcam communicate
    >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
    QuickCam 9.x and below
    ImageStudio 7.x and below
    Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
    Connection Issues:
    If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
    Changing Display Adapter Settings:
    If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
    1. Click on "Start," "Settings," and "Control Panel."
    2. Double-click on the Display icon.
    3. Click on the tab labeled Settings.
    4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
    5. Also, check with the manufacturer of the video card for updated video drivers.
    Low Light Boost:
    If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
    1. Open the QuickCam software.
    2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
    3. Choose "Advanced Camera Settings".
    4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
    5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
    6. Click OK when your are done.
    Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
    Televison & Video Logo
    264 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
