Question about Measuring Tools & Sensors
Problem with the starter motor on a briggs and stratton intek pro 65
4 Suggested Answers
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 395 Answers
SOURCE: Briggs and Stratton Intek V
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Posted on Sep 17, 2010
Wheres oil drain on 21 hp intek briggs
you should have a square plug on the side of the block usually on the starter side of engine
Aug 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a 25 h.p. Briggs intek . The starter tries to engage but will click once and does not turn the motor. I have a new solenoid and a new battery. The starter and starter wire will get warm when tried...
sounds like starter is bound up,take it off engine and apply battery voltage to battery cable connection on starter and see if starter will turn over if not the starter is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starter motor on rideon mower keeps snaping plaste gears
Use OEM Briggs & Stratton gear specifically for your model number engine and be sure you install the gear with the bevelled edges of the teeth UP
Sep 09, 2009 | Parks Optical 13.5hp Briggs And Stratton...
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
