Question about Haier HDN655E Dehumidifier
Haier HDN655E Dead
This morning went to empty the collection tank and the unit was not running. There was water in the tank, which had been emptied last night. From amount of water it appears the unit died overnight while running. Checked proper seating of the tank, tried manually manipulating the overflow switch, etc., etc. I have checked the power recepticle, etc. Is there an internal fuse I could check? Where is it? Any other suggestions?
  • Anonymous Aug 07, 2008
    will not run
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Posted on Sep 17, 2007
  • 11 Answers
It is a standard fuse that you can get at Radio Shack or an auto store. Just take it with you and have the sales person match it for size and amp.
Posted on May 29, 2009
I would like to receive the operation manual.
Posted on Dec 10, 2008
WHERE DO YOU GET THE FUSE?
Posted on Sep 15, 2008
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. I'll try to replace it and see what happens! thanks for the help! :)
Posted on Apr 03, 2008
SOURCE:
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
I turned my dehumidifier on and it started working. I unplugged it and plugged it back in, it started working again then just cut off. Now it's dead as a dodo. Please help!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Haier HDN655E Dehumidifier
The unit just stop working. i check that the unit was receiving 120 volt to the printed circuit board
heatman101
May 03, 2011 | Haier HDN655E Dehumidifier
Haier DM30EA-L Serial #AJ0240E0200A99251074. Comes on and runs for a short time then goes off does not collect any water. Sometimes comes on agail, runs a little and quits again, no water collection. I...
heatman101
Apr 28, 2011 | Haier HDN655E Dehumidifier
The unit keeps popping the breaker on the electric line.
Hi, The compressor has failed..
heatman101
Feb 15, 2011 | Haier HDN655E Dehumidifier
Haier HDN655E - water does not drain out of hose
check the hose connection,when new these units have a knock-out plug where the hose goes so if your only going to use the bucket and not the hose it wont run out the hose connection
Aug 01, 2010 | Haier HDN655E Dehumidifier
Problem with haier hd306 dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 02, 2009 | Haier HDN655E Dehumidifier
Kenmore Dehumidifier
if the compressor is running it sounds like a refrigerant problem or dead compressor in both cases its not cost efective to repair dan
Jul 05, 2008 | Haier HDN655E Dehumidifier
Connected Drain Hose - Is not draining, what gives?
Usually all you have to do is to remove any cap on the outlet fitting, attach the hose, & make sure it has a downhill run to the drain or well. Visual inspection should be enough to guarantee no obstructions exist.
Jun 24, 2007 | Haier HDN655E Dehumidifier
Haier HDN655E Dehumidifier Logo
788 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Bill Long
Evan Benson
Evan Benson
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
