Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Samsung clx 3175 says "scan Unit open or Paper Jam 2", what is theproblem with it?.
All cartridges are in but when its on it says scan unit is open yet the scan unit is closed, or jam 2, what is the real problem with this machine
4 Suggested Answers
  • 220 Answers
SOURCE: paper jam 1 - samsung clx 2160n
fuser needs replacing.
Posted on Jul 08, 2009
  • 107 Answers
SOURCE: Paper jam Samsung CLX 3175FW
I had the same issue, bought a bunch of sensors as they were only sold in lots, have some listed on ebay.
the proceedure is to remove the side covers, then the top cover and scanner assemblies an then the fuser, the sensor is then visible. not something that someone with no experience should really tackle.
if you decide to give it a go, see my listing in ebay listing number is 200520759089 or you can search by samsung jam fix
Posted on Sep 18, 2010
SOURCE: on a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Posted on Apr 21, 2012
Scan unit open or paperjam 2 message in Samsung CLX- 3185w
Please close the top cover (is just above the paper exit area)
Jan 31, 2013 | Samsung Office Equipment & Supplies
Clx-3175 laser printer always results in a paper jam -why? how to fix it? Help help please
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
Oct 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Hoe to enter mode service samsung clx3175n
Log into the service menu Samsung CLX-3175 without a numeric keypad similar tothe unit Samsung SCX-4623F/FN:
Consistent set of combinations of
"MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK" . Samsung CLX-3175XX/X with a numpad press: Menu, #1934, Menu
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
In
Samsung CLX-3175 to enter the reset require a password 1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru
Jul 10, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Replace Imagine unit Soon
Log into the service menu Samsung CLX-3175 without a numeric keypad similar to the unit Samsung SCX-4623F/FN:
In
Have any questions, you here http://skit-ltd.narod.ru/
Jul 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Scan unit open or paper jam2
In my case the printer was in a closet (as I do not want to keep it in my room and Wi-Fi allows me to do so) and it seems that the fusser heat attracted some unwelcome guests... Mice... Their faecal matter has fallen into all the bits and ends that sense the paper coming out of the fusser... Due to the heat they dried up and the printer started throwing "Scan unit open or paper jam2" errors... Took a while to figure out and vacuum all the faecal matter out and the printer is now running... Was getting ready to start taking it apart...
Jun 29, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I cannot print heavy paper. It consistenly jams. My HP inkjet prints the same weight of paper easily. Suggestions?
The maximum paper weight that should be used on the CLX-3175 is 163gsm, so if you use thicker paper it would jam.
Jun 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have a samsung clx-3175 printer telling me to replace the imaging unit I'v done that but it still tels me to replace it ,is there a way to reset it or what solutions do you have?
Consistent set of combinations of "MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK"
To enter the reset require a password
Aug 18, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Printer says "scan unit open or paper jam 2" Hav...
Dear
The printer paper jam-2 cover may be opened or not locked properly.
This door is at back side of the printer.
Thanks.
May 21, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
I can'r find the paper jam in the printer. screen
If not picking up the paper then it the Pick-up Roller just above where the paper tray is. Remove the paper Tray and Tip Printer back so you can see under the Printer. Take some rubbing alcohol and clean off the rubber roller
Service Manual found here Free...
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
18 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
