username & password make it blank don't write anything on there. reconnect it Note: cheak out all settings of GPRS make defoult setting of your service provider. when u connect your net with your pc / laptop. config your service provider's Access point number & port number
Ok,here's the solution,I have my lap top about 100 feet away from my router,have a man cave,I have it plugged in always and when the wind is blowing,my signal will get lost and I get the same reading as you do,but it picks right back up,it's the signal,my vizio,smart tv is connected by wifi and I loose my signal there too,Here's a video to watch,enjoy.http://www.youtube.com/watch?v=Lf1UgEJq8NY
You have to setup your internet connection on your DSI before being able to go on the internet and play online. Here is a step by step instructions how to setup your DSI Internet Connection:Wireless Connection:
Turn on Dsi and click on the wrench button to go to system settings.
install nokia pc suit then click connet to internet then settings then manually setting then only write the access point of the card which you have then press the ok then connet it
u need to call ur Mobile company and ask them u configure ur mobile for this service. Tell them u want to use the phone to access internt on your PC. They will help u setup the connection
Sounds to me that you dont have a router, you have a hub. If its a real router it would be assigning IP addresses to each computer. Sounds as if you are assigned the same IP to each computer (possibly). Make sure you have your computer set to dynamic IP not static. Instructions here. Other possible issue is the router is set not to manage IP in that case you need to access the router and change it to manage IP. To figure this out Google the make and model of your router to find manual.
Just to verify its an IP issue, turn off the computer that has access and reboot the other one and see if the one your rebooted gets a connection then. If so its a IP issue, if not check the cable connection and drivers for the NIC.
I have a Zyxel DSL modem that incorporates router features, but only has a single Ethernet port. When conneted to a Belkin wireless router I have to turn off NAT (in the Belkin) to gain access to the internet.
Hi, Nat2cool, Have you set the right protocol for the network? Sometimes you have to change it others, just leave the default, such as infrastructure and the like. I had the same issue and it was the protocol, the other is the switch. Make sure it's turn on. You'd be surprised how many people forget to slide the switch to the ON position.
I have fixed my PSP's over the years and have become almost an expert. Let me know if anything helps or if you need further help.
hi ! firned i have I Mate too but i dont have PC suit and i have a problem with net conection too please tell me how to access my imate with pc and internet
