Not Receive Mai 1 date I should have received already 7 days late where is my product
  • 542 Answers
You have posted this to the wrong site - you should contact the people you bought the product from
Posted on May 08, 2013
Why do I receive notifications on my cell phone, but not on my pc ?
Try to check if you have entered same details (e.g. email address).
Aug 12, 2014 | Lenovo Computers & Internet
Trying to find a date of manufacturing for my coke fridge model # CGD-C serial # 338540
It to is a dry cooler with two double lids and a single external cap catcher. Casters where available to aid in moving coolers such as the CGD-C.
SPECIFICATIONS:Vending Capacity: 288 Bottles, 12 CasesPrecool Capacity: N/ADimensions: 36 1/4" high, 45 1/8" wide, 28 7/16" deepWeight: 324 lbs.Production Dates: Late 1960's
Aug 04, 2013 | Computers & Internet
Number of days past the due date as a percentage?
That would depend on the terms of the payment. Two days late on a daily payment would be 200% while two days late on an annual payment would be about half a percent.
Jul 29, 2013 | Computers & Internet
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
I have lost my wii pin on parent control
1. Go into the Settings on your Wii
2. Click on forgot password.
3. Click on forgot secret answer.
4. You will receive a code.
5. Go to this website: http://wii.marcansoft.com/parental.wsgi?number=03253660&date=1114&submit=Get+Reset+Code
6. Enter your confirmation code and current date in your timezone.
7. You will receive your unlock code.
8. Enter the unlock code in your Wii settings.
Good luck and thanks for using FixYa.
Mar 10, 2011 | Nintendo Wii Fit for Wii
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
Key product got lost
How-To receive a valid Windows 7 keyTo receive a valid Windows 7 Beta/RC key just click here to visit the official Windows 7 Product Key page, or follow the instructions below.
Dec 30, 2009 | Microsoft Windows Vista Home Premium with...
REQUIRE EXCEL TIMESHEET Thursday to Wednesday. With DAY, date, start and end times with 1, 30 MIN meal break, total hours for the day (not to exceed 7), any time over 7 THEN GOES TO TIME IN LEIU COLLU
Here are already prepared template time sheets of which your description fits several.
http://office.microsoft.com/en-gb/templates/CT101172771033.aspx?av=ZXL000
May 30, 2009 | Microsoft Excel for PC
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
E-mail received
Be notified that the date on your computer does not have anything to do with the date of the mails you received. The date are autoset from the server so they must be correct, maybe you are are checking a wrong mail or something like you are not taking proper note, you may still try and check ur computer's date and make sure it is correct
May 05, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
