CAnnot go back to TV function
TMA function active . Lights up hen i press any button.
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
Check it by setup to an other code to your device.
Posted on May 07, 2013
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
My tail lights work just fine but my brake light will not light up when my brakes are being used, is it a fuse issue or wiring? 2003 Mitsubishi Montero Sport LS
Could be the brake light switch that is activated when you push the brake pedal. It is usually located by the brake pedal. When the pedal is up it pushes the switch in, no power to brake light. W HEN YOU PRESS PEDAL, SWITHCH BUTTON COMES OUT SENDING POWER TO BRAKE LIGHTS. CHECK THIS SWITCH FIRST.
Nov 26, 2010 | 2003 Mitsubishi Montero Sport
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
Forgot the administrator dept id et password of my ir2020 canon
go into service mode additional functions button hen press 2 and then 8 keys then press additionl functions button, then scroll through until you see clear press enter and scroll through until you see passwod clear then restart machine and be no administrator password then
May 20, 2009 | Canon iR 2016i Black and White Copier
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
