Question about Frigidaire FRT125GW (12 cu. ft.) Top Freezer Refrigerator
Fridge off for too long before it kicks into life
Is it normally for a fridge freezer to be "off" for a couple of hours before it comes back on? My f/freezer always works 30 mins on and then 60 mins off and so on. Week ago started playing up. Where the f/freezer would stay on for say 2 hours and then turn off BUT it would also stay off for 2-3 hours before coming back on. F/freezer has been switched off for a week in case anything was frozen. Switched back on not its still not working, meaning 2 hours on and then over 2 hours off with the temperatures rising in fridge ( up to 10oc) and freezer compartment but still not switching on. I can manually turn the dial but doesn't want to seem to do it automatically properly.
catriver
  • 878 Answers
SOURCE: Freezer not working properly...
Nortron, sounds like the system is restricted. I have seen a lot of these Frigidaires in the past 5 years with this problem. You should have a even frost pattern through the entire evaporator. I have been changing the compressor, evaporator and heat exchanger on these models. Your system on this refer is covered for 5 years, parts and labor for this failure. Here's hoping it's under 5 years. If it is, make sure all three componets mentioned above are changed out, otherwise the same deal is going to happen again down the road. Catriver.
Posted on Jun 10, 2007
Krazytech
  • 725 Answers
SOURCE: Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Posted on Aug 10, 2008
tborn6
  • 700 Answers
SOURCE: fridge freezer light on nothing else after transporting.
IS THIS A AUTOMATIC DEFROST UNIT? IF SO THEN THE DEFROST CLOCK PROBABLY IS BAD, LOOK UNDERNEITH BY THE COMPRESSOR AND THERE SHOULD BE A SQUARE ISH BAX THAT HAS 4 WIRES COMING OUT OF IT. TAKE AND TURN THE RED KNOB WITH A SCREW DRIVWER UNTIL THE COMPRESSOR COMES ON. IF THAT WAS NOIT IT TAKE A HAIR DRIER AND HEAT UP THE LIDUID LINE DRIER SOME TO TRY TO CLEAR THE RESTRICTION ON THE DRIER. GOOD LUCK (SORRY ABOUT ALL CAPS BUT GOT TIRED OF CORECTING THE SPELLING) NOT SHOUTING
Posted on Jan 11, 2009
tborn6
  • 700 Answers
SOURCE: My 18.2 cuft hotpoint refrigerator 2 years coils overheat
the drain on the unit is probebly clogged up or frozen . take and manually defrost the unit and check the drain line to see if i0ts clogged up.
Posted on Feb 01, 2009
  • 4793 Answers
SOURCE: brand new fridge. I have a bad smell like urine
smell is urea,it is a gas produced when plastics get hot,it will go away in time,but also check the drain for a blockage (syringe with clorine bleach)and if fitted, wipe out the condensate pan with clorine
last make sure the door seals fit all round as iif not flush any condensate will drip out from the front bottom.
Posted on Aug 12, 2010
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Why is Fridge Freezer not switching itself back on after 2 hours?
Good Afternoon S Trowell - Thank you for your post! Based on the symptoms you are describing it appears that the thermostat has lost its calibration and is not cycling on or off at the proper temperatures. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis and to proceed further.
May 06, 2013 | Frigidaire FRT125GW (12 cu. ft.) Top...
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Maytag MFI2568AES refrigerator was left open a couple hours, now it's not cooling at all.
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Jan 23, 2012 | Nor-Lake Refrigerators
Refrigerator shuts off for extended periods of time. The temp falls, ice melts, etc. then it comes back on, sometimes couple hours later , sometimes the next day.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Dec 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Apr 23, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hotpoint ff175b fridge freezer
I had the same problem. Hotpoint told me it was the electronic card, and I waited 3 weeks for them to get one in stock. Just been fitted and made no difference, though the Hotpoint man told me it was fixed. I have just spent half an hour "shaking and whaking" various bits at the back of the fridge freezer and the compressor has finally kicked into life.
Concentrate your shaking and whacking on the black square thing to the left of the compressor.
Going to quit my job and become a freezer repair man.
Nov 28, 2007 | Hotpoint FFA70 Bottom Freezer Refrigerator
Frigidaire FRT125GW (12 cu. ft.) Top Freezer Refrigerator Logo
44 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
