Question about 2003-2006 Ford Expedition Designer Auto Mat Floor Mats DM-FO-361F-1041 - Carpet
Engine will not run off choke
Rebuilt engine Holly 4 barrel. Ran fine for awhile. Will start and idle with manual choke pulled. Will not rev up or develope paower. Rebuilt carb twice. No difference. Plugged all vacuum lines. Points distributor, dwell 28 degs. Timing OK. Since it ran OK have to assume cam timing, compression, etc OK. Fuel pressure 4.5 psi. Clues, things to check I missed?
    Top Expert:
  • Intro-Tech A... Master
  • 50,010 Answers
Check the float level by the removal of the plug in the float bowl. At idle the fuel should be just visible in the hole threads. Adjust by turning the bolt that is at the top of the carby where the needle and seat is If you have vacuum operated second throat butterfly plates check that the gasket to the vacuum chamber is in correctly and not blocking the hole for the vacuum
Posted on Jul 18, 2013
Jingke carburetor choke off engine stops
Clean carb and air
mix screw needs set and rev screw
Apr 30, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
I have cleaned the gas tank, fuel lines and rebuilt the carb. It now runs but just at idle almost in the choke position. I have played with the throttle and it wants to die when I move it to normal ru
if it runs only in choke it sounds like its lean (choke reduces airflow and gets back to a mixture it will run on.....just). It could just be a small bit of crud in the carby jet. You cleaned the fuel system.....did you install or replace a fuel filter? sometimes cleaning the tank and lines stirs up stuff that needs to be filtered.....even though you may had cleaned and rinsed out a lot.
Nov 22, 2013 | Electrical Supplies
I bought a 1987 chevy C3500 w/350ci engine. When I start driving it the engine is really weak and the "choke" light on the dash always stay on. The power gradually increases as I drive the truck. Aft
The choke light is connected to the choke and the oil pressure switch.
The choke coil is heated electrically and from the engine heat to make it open.
The heater could be faulty and the choke is not opening fast enough.
It may have had a Rochester Quadrajet when new.
Jul 21, 2012 | Chevrolet C3500 Cars & Trucks
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
Got a 85 ford f150 has a 302 holly carb. was running fine ran low on gas and now cuts out wont back out of drive way idles fine but hit the gas and it stalls
strip and clean out the carb,or quick fix ,rev engine with air filter off and then hold hand over intake this may or may not not cure it .because when hand is held over carb and stops air the suction will draw any muck through the jets
Jan 03, 2010 | 1985 Ford F150
Engine idles excesivly high after carb was rebuilt.
You need a new choke pull off. They are around $30 dollars.
Dec 09, 2009 | Ford F-250 Cars & Trucks
I have a 66 ford mustang 1 barrel carburator
when the engine is fully warmed up check the choke. it should be wide open.if not it needs to be adjusted.
Apr 23, 2009 | 1966 Ford Mustang
2003-2006 Ford Expedition Designer Auto Mat Floor Mats DM-FO-361F-1041 - Carpet Logo
57 people viewed this question
Top Intro-Tech Automotive Vehicle Parts & Accessories Experts
RAYMONDO1953
Tom
David Harrelson
David Harrelson
Are you an Intro-Tech Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
