Question about Philips HDD070 MP3 Player
Player not responding
Screen shows=problem connect to computer.when i do nothing happens,computer says no player connected,have tried reset,etc etc still no joy.
Press the reset button mine on it was on the bottom of the mp3 player Ive just this moment stuck a tooth pick into the reset hole and heard a click and it has just started working I was looking at this post for the solution myself and have just found it.hope this helps.
Posted on Oct 06, 2007
SOURCE:
Why am I having problems trying to reset my Sony PRS350 e-reader?
Did you try to charge it up all the way before connecting to the computer?
Jul 20, 2014 | Sony e-Book Reader
The keyboard shows a connection but nothing happens on screen.
Delete device. reinstall. There may be a setting in the device manager that lets you use only one input method. So if the original keyboard will over ride? All this guess work would be eliminated if you give the os pc specs. If it's an external keyboard on a desktop then you may need to disconnect it? A laptop lets you use more than one input keyboard or wifi mini etc.
Oct 17, 2017 | FAVI Entertainment Mini Wireless Keyboard...
I've had my mp3 player for almost two years and it has worked fine. recently i tried hooking it up to the computer to charge it because it said low battery but nothing happens. i continue to get a blank...
Hi
Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If it is visible then try a reset and try again. If not then reset the player while it is connected with the system. This will resolve your issue.
Hope this helps...
Daniel
Sep 04, 2010 | Sony NWZ-E436F MP3 Player
Sansa Fuze, 8GB, unable to be turned on in the car after playing it just a short while ago, and is unable to connect to computer; screen is white.
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
-Also try to refresh the driver in your PC. Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. >>>><<<Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
I click the turn on button nothing happens and when i connect it to the computer it says connected but on the computer nothing comes out on the walkmans screen so how do i make it work again?
Try hitting the reset button on your Sony Walkman and if possible try connecting to a different computer to see if it's your computers problem
Jul 16, 2009 | Sony NWZ-E436F MP3 Player
TranscendTsonic 650 4GB mp3 player not starting, displays nothing
Transcend Tsonic 650 4GB mp3 player not starting up and not responding.. When I try to switch on the player, its not at all switching on.When I connect it to my PC, it shows busy symbol on its display and not responding from there on. Also its not getting recognised by PC. Please
Dec 24, 2008 | Transcend T.Sonic 650 MP3 Player
Sony nwz-S515
Try adjust the USB cable and/or switch which USB port it's connected to on your computer. Also just patiently let the player sit and try not to perform any other actions on the computer. When mine did this, I opened Media Player, wiggled the USB cable and waited. Eventually it connected and worked correctly.
Sep 28, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
No Resource Upgrade resource agan
ok, so u formatted your player, hence the green screen. So now all you have to do is download the firmware(match your player, sl with sl firmware, etc) then extract w/ winrar, u get 2 files so put them both in root folder (displaying music, video, etc) unplug turn off, on it will update then wait few min till it turns off, then turn on and ur player will work.
May 08, 2008 | Meizu Mini Digital Media Player
I disconnected my iriver when the computer froze, now it doesn't respond at all.
try taking out the battery and re-installing it. or try connecting to PC without a battery in it.
Mar 02, 2007 | iRiver T10 MP3 Player
Philips HDD070  MP3 Player Logo
27 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
