Question about Samsung LA32E420 32 inch 720p Multi System LCD TV for 110-220 Volts
Connecting ps2 to samsung lcd tv series 4
I connected my ps2 to samsung lcd tv. the screen is showing in black and white. how can i make it show in colors?
SOURCE: LCD Screen is White
The ribbon cable you require is here:
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1228041&query=Samsung%20VPD351&model=VPD351&path=98821,112905:98830
Posted on Oct 28, 2007
Merkader
  • 21 Answers
SOURCE: no colour when dvd player connected to tv
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
Posted on May 05, 2008
SOURCE: Samsung shows a white screen
what is the solution when my cellphone SGH-E250 turns to white screen?
Posted on Oct 05, 2008
rjel
  • 56 Answers
SOURCE: my lcd won't display a picture
the connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
Posted on Jun 30, 2009
SOURCE: connecting ipod to samsung lcd tv
how to connect I-pod to samsung lcd tv
Posted on Oct 16, 2009
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I have a problem with my samsung lcd it shows me black and white screen i try to set it with manual shows component -pc instead of av -tv
Looks like you need to reread the manual & properly connect. you are plugged into the PC & not the AV input & this is most likely your issue.
Dec 31, 2014 | Samsung LN-26B450 26 inch Series 4 LCD...
PS2 to Samsung LED
put the yellow one in to the green one on the tv componit side
Aug 23, 2012 | Sony PlayStation 2 (PS2) Console
How do i reset av and tv chanel on Samsung Series 4 PS42C430 42
i activate av1,av3 and av3 in service. my tv come on and off. i can't inter in service. samsung 42, PS42C430, SO HELP ME HOW TO DEACTIVE AND INTER IN SERVICE.
Jun 19, 2012 | Samsung PS42C430 42 Plasma TV
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Hi, I try to connect my PS2 to LCD TV and its has no color. The TV is LG and I tried the with SCART and with those holes on the side of TV (yelow, red and white). The strange is that when I start the...
make sure to set input on the TV is set to s-video.
If left on AV2 the picture is black & white.
Set to AV2S the picture is in colour.
http://www.avforums.com/forums/ps2/692572-ps2-picture-black-white.html
here some troubleshooting steps to help find out what maybe wrong
1. try a different tv 2. if you have a friend with a ps2 try borrowing their cable to make sure its not the cable. 3. try your friends ps2 on your tv.
Jun 01, 2011 | Video Game Consoles & Games
Why would my ps2 screen only be in black and white
Make sure that you have the plugs in the correct sockets on the back of the television , as well as make sure the tv is on the correct setting, NTSC, PAL, SECAM, etc. Good luck.
Nov 25, 2009 | Sony PlayStation 2 (PS2) Console
Samsung LA46M81BD LCD 1080p white horizontal lines
East way to see if it's a TV iussue or signal issue is use another input (DVD, VHS, etc).
It sounds like there is a dirty or improperly seated connector on the LCD panel itself. However, this can also be a sign of a bad panel as well.
Nov 21, 2007 | Samsung SyncMaster 243T 24 in. LCD...
Samsung LA32E420 32 inch 720p Multi System LCD TV for 110-220 Volts Logo
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
