Home | Cuisinart | DGB-300 Coffee Maker | Cuisinart BGB-300
Cuisinart DGB-300 Coffee Maker
Problem for Cuisinart DGB-300 Coffee Maker
Cuisinart BGB-300
By Aussie_1 on Aug 10, 2007
Hi all, Yep this morning no more Coffee for me!
My DGB-300 stopped graining coffee beads the main shaft for the graining dispenser does not spin? Will try and pull it apart this morning
Any ideas ???
A?
Solution #1
posted on Oct 06, 2007
Somewhat Helpful)
KC720
Rank: Apprentice
Rating: 70%, 2 votes
I just got mine to work. It seems that so much water condensation gets into the grinder that there was rust stopping the grinder from moving. Just remove all the parts, especially the blade and basket holder assembly. Take a pair of pliers and twist the grinder stem manually to loosen the rust. Turn it a good number of times and then test it out. I didn't want to use WD-40 on something my wife uses everyday. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Cuisinart DGB-300 Coffee Maker
Questions and Unsolved Problems for Cuisinart DGB-300 Coffee Maker
Do you recommend Cuisinart DGB-300 Coffee Maker?
Answer
Answer
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have... (More)
Answer
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go,... (More)
Answer
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of... (More)
Answer
broke grinder basket lid how can i get one
Answer
cuissinart coffee maker part, model DGB-300; Need replacement of Reservoir cover...brown ...where... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cuisinart DGB-300 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
