Question about Home
What are the different type of plate shapes? - Home
    New Friend:
  • 53 Answers
Rim-shaped plates originated in Europe. In the West, food portions are cut into bite-size pieces at the table, and the rim-shaped plate is made with a well that collects the juices that flow from the food.
Coupe-shaped plates have no rim and accommodate the way food is cooked and served in the East. In the East food is cut into bite-size pieces in the kitchen and cooked quickly over high heat.
To allow space for the courses on one plate, the diameter of the coupe-shaped dinner plate is approximately 1 inch larger than that of the rim-shaped dinner plate.
-http://www.etiquettescholar.com
Posted on May 06, 2013
Daisy 22 cal pellet, model 250, scotland. Trigger fix
Sounds like you are suffering from good old wear and tear. It might be possible, if you are willing to invest the time and effort, to re-make the worn parts. I would suggest that if you decide to try this, you use a hardenable steel, like W2, O1 or even 1095. Shape the parts a bit oversize and drill any required holes. Then file to the correct size - take it SLOW. Then harden the parts, by heat treating them. You can find steel by researching knife maker or knifemaker supplies websites. Also a good source for instructions on heat treating the steel as different steels are heat treated differently, some quenched in water or brine, some in oil. be sure to drill any holes before heat treat as you won't be able to do so afterward. You will need a grinder or belt sander for shaping after heat treat as well.
Best of luck,
Feb 21, 2015 | Optics
Tip
Brass Tube Fitting
The essential step of tube fitting production include heating, melting, mixing and conveying the raw material into a particular shape. It is important that this shape is maintained during the cooling process. All Brass tube fittings are made in accordance with ASTM standards. All diameters of solid wall Brass tube fittings are continuously extruded through an annular die. Thermoplastic fittings are either injection or compression molded. They are fabricated using section of pipes or machined from molded plates.
Om Tubes Brass Tube Fitting connects different types of tubes to one another. It can be used for in-line, offset, multi-port, and mounting configurations. Various tubing sections like pipe, hose, or other components are connected through tube fitting. Usually the system is configured with straight sections connected by fittings or some specially formed connections and joints. Om Tubes being Brass Tube Fittings Distributors provides you with best quality & services. Products at Om Tubes are of various wall types and all are produced in accordance with the requirements of a variety of industry standards and specifications like ASTM and AWWA. We sell Good Quality Brass Tube Fitting at Om Tubes.
http://omtubes.com/brass/brass-tube-fittings
on May 08, 2017 | Miscellaneous
Do dog beds come in different sizes and shapes?
Yes, dog beds come in different s for different dog types. Also the shapes of the beds vary and come in different shapes like oval, round, rectangular, and square.
Aug 29, 2012 | Anima Dogs
Installing doel fin how do you
Doel fin made 2 different designs, first came the one piece design with a clear slot where the lower unit went and it bolted thru the cavitation plate.
The second was a 2 piece which fit on both sides of the cavitation plate.
Both were shaped like a wing- flat on the bottom and arched across the top.
Dec 18, 2011 | Dolphin Boating
I want to know what is inside the printer cartridge
The ink cartridge are of different type and contains ink in different form.
  • Thermal Ink jet Cartridge (HP, Canon) - The cartridge contains a liquid ink, which is heated by a heating plate on the cartridge. A bubble is formed which forces the ink which comes out of the nozzle.
  • Piezoelectric Cartridge (Epson) - The cartridge contains piezoelectric crystal, which when current is applied changes shape and size forcing ink out from the nozzle.
  • Toner (Laser Jet Printer) - A drum contains powdered ink (toner), which is spreads on the paper using negative and positive charges and the heater sticks the ink on the paper.
Regards,
Shrey
Jun 07, 2011 | Computers & Internet
Need to adjust the burners the flames to high
Hello there:
Please follow these very easy steps and this should help you
Instructions Things You'll Need:
  • Gas Ranges
  • Screwdriver Sets
  1. Step 1 Find the tube that feeds the burner. There's a burner air adjustment on it that mixes the air and gas.
  2. Step 2 Look to see what type of burner air adjustment you have: It will either be a barrel-shaped chamber or triangle-shaped with a cover plate.
  3. Step 3 Loosen the air-shutter screw on the barrel-shaped type. This screw is on the end of the barrel closest to the burner.
  4. Step 4 Open the shutter on the barrel-shaped type by turning it counterclockwise; close it by turning it clockwise. Opening it will add more air, which will make the flame higher; closing it will reduce the air in the mix and lower the flame.
  5. Step 5 Loosen the screw holding the plate on the triangle-shaped burner air adjustment. Don't remove the screw - it just needs to be loose enough to move the plate.
  6. Step 6 Move the plate so that the opening is either more open or more closed. More open will make the flame higher whereas more closed will lower the flame.
  7. Hope this is very helpful for you
  8. Best regards Michael
Feb 02, 2010 | Kitchen Ranges
Soldering iron troubleshooting
Bits: It's useful to have a small selection of manufacturer's bits (soldering iron tips) available with different diameters or shapes, which can be changed depending on the type of work in hand. You'll probably find that you become accustomed to, and work best with, a particular shape of tip. Often, tips are iron-coated to preserve their life, or they may be bright-plated instead. Copper tips are seldom seen these days.
Aug 27, 2008 | Cooper Industries Weller Soldering Iron,...
Home Logo
522 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
