Question about Fiesta Blue Ember Gas Grill
Need replacement it has rotted away and fallen apart
    New Friend:
  • 11 Answers
Visit www.ibuybarbecues.com, they have really good selection and decent prices
Posted on May 10, 2013
Vacuum line leak
It could possibly be a vacuum leak, try replacing the Idle Air Control Valve about a $45 part..
Trace down the hose(s) that is (are) torn, dry rotted or just fallen off and replace them also.. I hope this works.
May 12, 2013 | 1999 Pontiac Montana
I HAVE A HOTPOINT 7KG AQUARIUSA+ WMF740 AND WHEN IT SPINS IT MAKES A LOAD KNOCKING NOISE AND ITALSO LOOKS LIKE THE SILVER DRUM HAVE FALLEN A BIT
the trunnion (spider) behind the silver drum has corroded and broken away from the drum,you will need to purchase a new drum and trunnion and remove the front of the machine to replace it as well as your at it replace the drum bearings for the trunnion shaft while you have it apart,dont wait too long or the drum can completely break away from the trunnion and breach the cabinet
Jan 07, 2013 | Washing Machines
I need to replace the switch that starts the washer when it's closed.The switch has fallen apart.Where I can get a switch and what is the approximate cost. The switch is 0.5 HP ,125v and 60 Hz.The...
I bypassed mine , got a connector and hooked the wires together. Runs with lid up or down, just remember to keep children away from washer and don not reach into tub while running.
May 23, 2011 | Kenmore Washing Machines
All my vacume lines on my 85 s10 are dry rotted and a bunch of them have fallen apart but i cant find a diegram that even comes close to mine including the 4x4 transfer case can some one e mail me one at...
With out knowing the following your engine displacement and if its is federal, California or high altitude emission than its very hard but this may help. If you go to autozone.com in the repair section you can get a diagram for all. You have to register but its free and they have everything you may need,
Feb 20, 2011 | 1985 Chevrolet S-10
Radiator promblem just falling apart like its rottening away
best thing to do is change it .these things do rot and are prone to weathering and fluids in side. good luck
Feb 07, 2010 | 2004 Jeep Grand Cherokee
F9 fault. looks like inside drum has fallen away
one of the springs has come off - also ck the lower shock - it may have come apart
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front sway bar link kit, what is the order of installation. all my bushings are rotted away.
Remove the sway bar links from lower control arms. Replace the sway bar mount to frame bushings first. Then install sway bar link bushings. Note how they come apart and install in the same manner.
Dec 12, 2009 | 1999 Ford Expedition
Craftsman leaf blower will start but has no blowing power
Clean the carburetor and replace the fuel lines - The lines on mine were totally rotted - The larger hose crumbled in my hand - The fuel filter had long since fallen off....
Sep 03, 2009 | Craftsman Garden
The guitar lead plug has fallen inside.
The safest way to fix this is to take the amp apart to get at the jack. If the jack is a solid black plastic shape, then you should replace the jack completely. Otherwise you should have access from the side of the jack to remove the piece of hte plug that broke off.
Dan
Feb 18, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Fiesta Blue Ember Gas Grill Logo
43 people viewed this question
Top Fiesta Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
