Question about Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007
Key will not turn in the ignition
After recharging the batter, the smart key will not turn in the ignition. No horn, no lights.....
    Champion:
    Scholar:
  • 227 Answers
Disconnect the battery for 10 minutes incase the battery charger messed with the computers in the car.
Always disconnect the battery before charging it on modern vehicles (especially German Vehicles) as things like this happen.
Posted on Oct 24, 2013
Harley davidson electra glide 2001,batter when dead,charged on slow charge on the bike,now have red key light flashing,no ignition,can you help,thanks
Not sure what the red key light is.. Possibly anti theft?? If you recharge a battery, you should disconnect all wiring from it first. try disconnecting the bike battery connections, recharge the battery and when charged, reconnect the bikes connections. Hope it works.
Jan 05, 2015 | Motorcycles
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
I have full battery power but no power to my dash ignition lights when i turn key put have head lights and horn. on my 2008 chevy cobalt
Some cars have inline fuses in the battery cables and have multiple connections for components making one get power and others not. If all your fuses are good, the next thing to look at is the electrical part of the key switch. Usually there is the mechanical part with the tumbler, and the electrical part.
Dec 07, 2013 | 2008 Chevrolet Malibu
Problem starting
What they did was upgrade the system here try this its from Kia.
Turn the ignition key to the "ON" position. Reconnect the negative battery cable. Turn the ignition key to the "OFF" position.
4. Transmitter Programming Procedure:
1. Turn the ignition key to the "ON" position. Do not start the engine.
2. Locate the "disarm/programming" button which is secured to the remote start wire harness behind the left lower dash panel.
3. Press and hold the "disarm/programming" button for 10-15 seconds until the horn beeps 3 times.
4. Release the "disarm" programming button.
5. Press the red Find/Panic button on the remote start transmitter one time. The horn will beep one time indicating that the transmitter code has been learned. Repeat for each additional transmitter.
6. Turn the ignition key to the "OFF" position.
5. Function Check:
Refer to the vehicle specific "Remote Engine Start" installation instructions for a complete list of functions to be verified before delivering the vehicle.
Aug 05, 2012 | 2011 Kia Sorento
My theft light on my 1998 Lincoln Navigator is on and the car won't start.
Deactivating/activating the autolock feature...
Before following the procedure, make sure that the ignition is OFF and all vehicle doors and the liftgate window are closed.
You must complete steps 1-5 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Also, if your vehicle is equipped with a coded-key anti-theft system. Only the correct key will be able to start your vehicle. If your keys are lost or stolen, you must take your vehicle to a Ford/Lincoln-Mercury dealership for re-programming.
Programming additional keys If you need additional keys electronically coded for your vehicle, spares can be purchased (a maximum of 16 keys can be programmed). To program a new key, perform the following procedure:
1. With the coded key in the ignition, turn the ignition from ON to OFF.
2. Within 15 seconds of turning ignition off, insert the new coded key
into the ignition and turn it from OFF to ON or START. If successful, the
THEFT indicator light will illuminate for two seconds. Repeat procedure
for all new keys.
If key coding fails, the THEFT indicator light will flash.
Coding failure can be caused by any of the following:
² The new key was not inserted into the ignition within 15 seconds.
² 16 keys have already been programmed.
² The new key does not have an electronic code.
Other details can find in the 1998-Lincoln-Navigator-Owners-Manual
Good luck (remember comment and rated this).
Jul 09, 2010 | Cars & Trucks
Horns blares continuously when key is removed from ignition!
Locate the fuse for the horn and see if nothing else is ran off the same fuse then remove the fuse.
Sep 26, 2009 | 2001 Ford Explorer Sport
Auto Lock Activation
Deactivating/activating autolock
There are 3 methods to enable/disable this feature. One through your
dealer, the second with a power door unlock/lock sequence and the third
with the keypad.
Before following the activation or deactivation procedures, make sure
that the anti-theft system is not armed, ignition is off, and all vehicle
doors, liftgate and liftgate window are closed.
Controls and features
Power door unlock/lock
procedure
Keyless entry key pad procedure
1. Enter 5 digit entry code
2. Press and hold 7/8 control
3. Press and release 3/4 control
4. Release 7/8 control.
The user should receive a horn
chirp
to indicate the system has
been disabled or a chirp followed by
a honk to indicate the system has
been enabled.
Smart unlock
This feature prevents the driver’s door from locking while the key is in
the ignition. This feature will unlock only the driver’s door if the key is in
the ignition cylinder, the driver’s door is ajar and all doors are locked
using the interior trim switch. If these conditions are met, the entire
vehicle will lock and the driver’s door will unlock within 1 second.
127
May 15, 2009 | 2002 Ford Explorer
Car alarm won't turn off after recharge of battery
When the battery is disconnected and replaced and when the battery is drained and then recharged, the anti-theft device in your car was activated.
Refer to your Manual to arm and disarm the anti-theft device, it should reset
If this does not work using the remote, try locking and unlocking the driver side door with the key and IMMEDIATELY START the car.
Dec 09, 2008 | 2002 Honda Odyssey
Alarm sounds everytime key removed from ignition?
There is a switch either in or on the driver door that turns on the interior lights and tells the module the door is open and the key is still in the ignition, this sounds the alarm, check all the doors and make sure they turn the interior lights on and off when the doors are opened and closed.
Nov 21, 2008 | 2007 Volvo V70
Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Logo
80 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
