Question about Home
Can you get a water bottle with a filter in it?
    New Friend:
There is a new trend now you can have you emergency water even if you are in a desert. Puritii Water Air Where Nothing is Everything
Posted on Dec 22, 2016
    New Friend:
  • 75 Answers
Camelbak Groove
The Groove holds 600ml of water and has a carbon filter that is partly made of coconut (really) built into the straw, so it instantly turns the stuff from the tap into fresh water, whenever and wherever you are.
Posted on May 06, 2013
I use rain water in my tefal express compact. Is this ok or should I use bottled ? Do you need to empty iron after every time you use it ?
excellent iron an not that heavy as you would expect
empty every time after use
rain water can be used ...bottle water only well filtered water
..will still scale up
distilled water is better for a warranty claim
Oct 11, 2016 | Tefal Irons
I cleaned my water cooler with vinegar but the water still taste bad. What can i do ?
it it is a plumbed in unit running off utility water supply, there is a small ceramic water filter assembly that can be fitted into the water inlet side of the unit
because it is extremely fine it removes the contaminates that make the taste if that doesn't work you can fit in tandem a charcoal filter after that ceramic to guarantee perfectly clean tasteless water
add to the fact that every 12 months ( depending on volume usage) the ceramic filter can be removed and the contaminates scraped off the surface using a knife which regenerates the filter
if it is bottle feed then clean out the holding tank using bleach, wash thoroughly and allow water to run from both taps for a few minutes to remove all residue bleach , the fit new water bottle
spare bottles are subject to algae growth ( taste ) if stored in a well lit area so store spare bottles in a dark room ( closet , under bench etc )
Jul 12, 2016 | Greenway Vitapur Point-of-Use Water...
The truth about fiji bottled water
Just about all bottled water is tap water ran through a bunch of filters.
But FIJI is the worst.
Apr 06, 2016 | Fiji Water Wine & Spirits
Can plastic water bottles be dangerous to my health?
Chemicals, called phthalates, can leak into the water inside the bottles afsfter several weeks. These chemicals have been known to alterhormone levels. There are standards for the amount of phthalates that can be present , but there are no legal limits that can be enforced.
Just better to drink filtered tap water in my humble opinion.
Feb 06, 2013 | Wine & Spirits
Is bottled water any different from tap water?
There are many differences between bottle and tap water that change from brand to brand. For instance, some bottled water just just filtered and some is spring water. Tap water is always unfiltered.
Jan 10, 2013 | Wine & Spirits
I have a sunbeam 1387 warm mist humidifier. I need to know how to clean scale from the filter. It looks like it can be taken apart. Can it?
Actually, Carol, it shouldn't be necessary to take the unit apart. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and allow it to sit overnight. Then empty the solution and fill the tank with Bottled Distilled Water. Turn the unit ON and allow it to run for 1 hour. Then empty any remaining Distilled Water. Doing all the aforementioned, should have not only cleaned the filter, but also the unit itself. If you use Bottled Distilled Water in the future, rater than tap water, the filter and the plumbing of the unit will stay clean longer and will require less maintenance.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | Sunbeam Warm Mist Humidifier Dehumidifier
Water not flowing from bottles...
The water containers have a small exit valve that fits into the mist head compartment. Should particles (Lime or Calcium) collect within the valve; no water will exit. Check the reservoir outlet and use Vinegar solution for cleaning parts. Use Distilled or Filtered water ONLY.
Feb 05, 2018 | Bemis 427 300 Humidifier
The filter is located in the washer bottle itself. Remove the pump(pull out) from the water bottle and the filter is the black seal the pumps fits into. Pull this out and rinse.
Mar 25, 2009 | 1996 BMW 318
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Dirty water line from filter
Attach flexable rubber line from water bottle, like is used for race bicycle riders,or tape up a hose to a water bottle. Turn off valve at water pipe leadign to line to filter. Remove filter. place a pan to catch water under the machine. Attach A small diameter hose to water line where water exits to glass.With machine turned on and your rubber hose attached turn bottle upside down and squeeze while pressign glass lever. Flush through approximate one quare or until water stream is clear. Their is no pumb ofor flow the line preaure is al that moves the water so backflushing is easy.
Dec 14, 2008 | Frigidaire FRS26R4A Side by Side...
Home Logo
799 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
