Question about Boating
Autohelm st50 wind
I am operating autohelm st30 speed, st50 echolot and st50 wind together. on the wind display , the wind direction shows only in the same direction, on windspeeddisplay shows the boatspeed in knots. i have no glue how it works.
    Sergeant:
  • 415 Answers
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
Posted on Mar 04, 2014
2 Suggested Answers
  • 18 Answers
SOURCE: autohelm st50 how to calibrate??? wind instrument
I had one. Don't think you calibrate it. Reading is relative to it's mounting base. To change the direction reading, you would need to rotate the base.
Posted on Jun 18, 2009
Digital display shows bobbin wind. Bobbin wind spindle moves slightly. When depress foot pedal, stitches for only a minute- stops. Cannot select any stitches as menu display remains on bobbin wind.
try putting a bobbin on to wind and then take off again, make sure when you do that the bobbin holder clicks back into the sewing position not the winding, you might need to give it a little push in the right direction then see if it sews ok for you. if not may need a service call.
Jul 20, 2017 | Sewing Machines
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Wind sensor doesn't work
Test all wires for continuity. 90.8 % of problems are caused by faulty wiring.
Aug 13, 2017 | dr. Tech WA-1080PC-T Solar Wireless Home...
We just got a new springfield 91751 weather station and we can't get a reading on the wind speed and direction.
We just got one for Christmas and can't get the wind speed to work either. And it can be pouring rain outside and it just shows cloudy.
Aug 24, 2010 | Sport & Outdoor - Others
Autohelm mast Wind speed unit. Bottom bearing worn out. Can this be replaced, or where can I get a full replacement unit. Len
The part number for the lower pod is Q002. I am willing to bet that Raymarine will not have any more of these. The new ST60+ version will read faster than what the wind is actually.
May 15, 2010 | Boating
Autohelm st50 how to calibrate??? wind instrument
Jun 10, 2009 | Boating
Erratic operation of Autohelm ST50 Tridata paddlewheel speed log
Hi Jim , I have the same problem. Did you solve yours thank you Martin RestauratorHamburg a yahoo.com
Apr 07, 2009 | Raymarine Boating
Raymarine ST50
http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Oct 19, 2008 | Raymarine ST60 A22012-P GPS Receiver
St60 wind instrument
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Dec 13, 2007 | Raymarine ST60 A22012-P GPS Receiver
Boating Logo
114 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
