Question about Home
What is a Gratin pan? - Home
    Problem Solver:
  • 48 Answers
Gratin dishes are shallow and usually 10+ inches. Some are pretty enough to go from oven to serving dish on the table.
Posted on May 06, 2013
What food names start with the letter H?
Food names start with letter H:
1.Hare
2.Ham
3.Haricot
4.Hyson
5.Hydromel
6.Hummus
7.Husk tomato
8.Haslet
9.Hash
10.Hay
and many more........
Sep 22, 2017 | Cooking
How do i replace a oil housing gasket on a 2000 3.8 grand prix?
You'll need new gasket for oil pan,,,proper socket and drive to fit the bolts around circumference of pan.scraper and new oil or catch pan to save old oil, approx 5 qts . 1/ Begin by draining oil....drain plug on lower part of pan..get that wrench also.....it is larger than bolts arund pan......2/after drained, put drain plug back in and tighten snugly. not too tite......3/remove pan by removing all the nuts around pan, dislodge pan from it's seal , may takea little tender tapping with rubber mallet to release the pan, do not pry at lip, you may damage pan....4/ Clean both sealing surfaces of old gasket.....5/ dampen new gasket with oil and put it on pan in proper position, ....6/put bolts back in pan one on each side to hold pan up,,,put rest of bolts in pan and tighten in random pattern around pan trying to keep pan even at mating to engine.....7/when pan is on and fairly snug, fill the oil into filler at proper fill neck w proper amt of oil. about 5 qts,U.S......Make sure drain plug is not dripping, if so, put a little more torque on it. Not too much,they are prone to strip. Done. Or, about 40 dollars at oil change place.
May 16, 2017 | Cars & Trucks
Yamaha outboard motor
Gear shaft cold be twisted frm corrosion,check if cable is pushing linkage fully back,if gratin or jumping out of gear could be worn gear and clutch dog
Oct 24, 2013 | Boating
Samsung washer
Tighten the hose to make sure the gratin of washer hasn't rubbed it loose. Then run your hand up and down length of hose feeling for any kinks that would stop water from running out.bends are ok but twists or kinks will cause all water that ran in washer to fill to come out of the back
Jun 30, 2013 | Washing Machines
Hotpoint SD97PI oven self cleaning funtion and grill not working
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort.
Jun 22, 2012 | Hotpoint Ovens
How to do a transmission fluid/filter change on a gmc 1500 2wd v8 350 step by step
Raise the vehicle. Refer to Vehicle Lifting. Place a drain pan under the transmission oil pan. Remove the oil pan drain plug. Remove the oil pan bolts. Remove the oil pan. Remove the gasket. Remove the magnet. Remove the oil filter. Remove the filter neck seal. The transmission oil pan gasket is reusable. Inspect the gasket and replace as needed. Clean the transmission case and the oil pan gasket surfaces with solvent. Install the filter neck seal. Install the oil filter. Install the oil pan gasket to the pan. Install the magnet into the bottom of the pan. Notice: Refer to Fastener Notice in Service Precautions. Install the oil pan to the transmission with seventeen bolts. Tighten the oil pan bolts to 11 Nm (97 inch lbs.) . Apply a small amount of sealant GM P/N 12346004 to the treads of the drain plug. Install the oil pan drain plug. Tighten the oil pan drain plug to 18 Nm (13 ft. lbs.) . Install Dextron Automatic Transmission Fluid. Lower the vehicle.
Jul 04, 2011 | GMC Sierra 1500 Cars & Trucks
How difficult is it to change the oil pan on a 1997 gmc jimmy 4x4?
4WD To Remove:
  1. Remove or disconnect the following:
    • Negative battery cable
    • Oil level indicator
    • Front differential assembly
    • Starter
    • Transmission cover
    • Oil pan drain plug and drain the engine oil into a suitable container
    • Remote oil filter pipe adapter
    • Remote oil filter hose clip bolt on oil pan
    • Starter wire harness bracket stud
    • Transmission oil cooler pipes (if equipped)
    • Access plugs for oil pan rear nuts
    • Transmission to oil pan bolts
      NOTE: The low oil level sensor is not reusable.
    • Remove and discard the engine oil level sensor (if applicable) gm_truck_43_ol-pn_blts.gif
    • The oil pan
    • The oil pan gasket
  2. Discard the oil pan gasket.
  3. Clean all sealing surfaces on the engine and the oil pan.
To Install:
Note: Whenever the transmission and the engine oil pan are removed from the engine at the same time install the transmission before the oil pan. This is to allow for the proper oil pan alignment. Failure to achieve the correct oil pan alignment can result in transmission failure.
  1. Apply a 0.197 inch (5 mm) wide and 1.0 inch (25 mm) long bead of adhesive GM P/N 12346141 (Canadian P/N 10953433) or equivalent to both the right and left sides of the engine front cover to engine block junction at the oil pan sealing surfaces. gm_truck_43_ol-pn_ahsv_loc_f.gif
  2. Apply a 0.197 inch (5 mm) wide and 1.0 inch (25 mm) long bead of adhesive GM P/N 12346141 (Canadian P/N 10953433) or equivalent to both the right and left sides of the crankshaft rear oil seal housing to engine block junction at the oil pan sealing surfaces. Note: Always install a new oil pan gasket. The oil pan gasket and oil pan must be installed and the fasteners tightened while the adhesive is still wet to the touch.
  3. Install the new oil pan gasket into the groove in the oil pan. Note: The oil pan alignment must always be flush or forward no more than 0.011 inch (0.3mm) from the rear face of the engine block.
  4. Install or connect the following:
    • The oil pan onto the engine block
      1. Press the oil pan gasket into the grooves of the engine front cover and crankshaft rear oil seal housing
      2. Slide the oil pan back against a suitable straight edge
    • The oil pan bolts and nuts, but do not tighten
  5. Measure the pan-to-transmission housing clearance using a feeler gage and a straight edge. gm_truck_43_ol-pn_trnz_clrc.gif
    • Use a feeler gage to check the clearance between the oil pan-to-transmission housing measurement points
      1. If the clearance exceeds 0.011 inch 0.3mm) at any of the 3 oil pan-to-transmission housing measurement points (A), then repeat the step until the oil pan-to-transmission housing clearance is within the specification
      2. The oil pan must always be forward of the rear face of the engine block
  6. Tighten the oil pan bolts and nuts in sequence
    • Torque to: 18 ft lb (25 Nm).
  7. Measure the clearance between the 3 oil pan-to-transmission housing measurement points in order to ensure proper alignment.
  8. Install or connect the following:
    • A new oil pan drain plug seal (O-ring) onto the oil pan drain plug
    • Oil pan drain plug into the oil pan
      1. Torque to: 18 ft lb (25 Nm)
    • New low oil level sensor
      1. Torque to: 115 in lb (13 Nm)
    • Transmission to oil pan bolts.
      1. Torque to: 35 ft lb (47 Nm)
    • Access plugs for the oil pan rear nuts
    • Oil filter hose clip bolt to the oil pan
    • Transmission cover and bolts.
    • Starter motor
  9. Fill the engine with oil.
  10. Connect the negative battery cable.
Dec 19, 2010 | 1997 GMC Jimmy
How do I change the tranny fluid in my 1998 cadillac catera
Fluid - A/T: Service and Repair
Transmission Fluid and Oil Filter Changing
REMOVAL PROCEDURE
1. Raise and suitably support the vehicle. Refer to Vehicle Lift Points.
2. Place drain pan under pan
3. Remove oil pan bolts from front and sides only.
4. Loosen the rear oil pan bolts approximately four turns.
5. Lightly tap the oil pan with a rubber mallet or pry to drain the fluid from main case.
6. Remove the oil pan bolts from rear oil pan and gasket.
7. Remove front oil pan bolts leaving one corner bolt in loosely.
8. Lightly tap oil pan with rubber mallet or pry to drain fluid.
9. Remove the following remaining components:
^ The front oil pan bolts
^ The oil pan
^ The gasket
10. Remove the oil filter bolts and filter.
11. Clean the following components:
^ The transmission case
^ The front adapter case
^ The oil pan gasket surfaces with solvent
^ Air dry
^ All traces of gasket material must be removed
INSTALLATION PROCEDURE
1. Install the gasket.
2. Install the oil filter.
3. Install the bolts.
^ Tighten the transmission oil filter bolts to 20 Nm (15 ft. lbs.).
NOTICE: Refer to Fastener Notice in Service Precautions.
4. Install the front oil pan.
5. Install the front oil pan gasket
6. Install the front oil pan bolts
^ Tighten the front oil pan bolts to 11 Nm (96 inch lbs.).
7. Install the following components:
^ Install the pan
^ Install the gasket
^ Install the bolts
^ Tighten the oil pan bolts to 11 Nm (96 inch lbs.).
8. Refill the transmission with DEXRON III through oil pan fill plug on the side of the (main case) oil pan. Fill the transmission to lower edge of oil
pan fill. Fill plug opening using and oil suction gun.
^ Tighten the oil pan fill plug to 45 Nm (33 ft. lbs.).
9. Lower the vehicle.
10. Check the transmission fluid level. Refer to Transmission Fluid Checking Procedure.
Sep 13, 2009 | 1998 Cadillac Catera
When i go to four wheel drive it sounds like the gears are gratin
no this is not normal, sounds like the transfer case or the front hubs may be defective, have it road tested by a transmission shop, they should do it for free.
May 31, 2009 | 1998 Isuzu Rodeo
Home Logo
608 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
