Question about Home
Should I cover my roasting pan or not? - Home
    New Friend:
  • 60 Answers
When using a roasting pan, it depends on the type of meat and the recipe if you should cover the pan or not.
meat with a high fat content eg duck doesnt need to be covered.
lean cuts should be covered when roasted for a long time to keep the juices and soften the meat.
Posted on May 06, 2013
How long to cook a 2.6kg of stuffed topside roast.
Use a probe thermometer and remove from the oven at 140'F for medium rare. Rest for 15 minutes tented in foil and then carve. The meat needs to be good quality to cook medium rare. The more you cook the more tender it becomes, as long as you keep some moisture in the pan. or cover with a lid or foil.
Or the old way, and some good tips here.
https://canadabeef.ca/wp-content/uploads/2015/09/roasting-foodservice.pdf
May 20, 2018 | Grilling
How long and what temperature do I roast a 12 lb. boneless pork loan roast?
This cut is long and narrow so cooking it for so many minutes per pound won't work. The best way is to use a probe thermometer. If the skin is on it, score it and pour a full kettle of boiling water over the skin. Pat dry and season it. The skin will come nice and crisp.
Sirloin Pork Roast 4-5 lbs. 145°-160° F. 25-40 min. per lb. Stuffed Pork Loin Chops 11/4-11/2-inches 165° F. Varied (based on type of stuffing) Tenderloin (roast at 425° F.) 1-11/2 lbs. 145°-160° F. 20-35 min. Whole Pork Loin (boneless) 8-10 lbs. 145°-160° F. 8-11 min. per.
Roasted Boneless Pork Loin Recipe - The Spruce
https://www.thespruce.com/roasted-boneless-pork-loin-recipe-995289
Rating: 4 - ‎350 reviews - ‎1 hr. 15 min. - ‎324.9 cal
In a small bowl, combine the oil, garlic, salt, pepper, and herbs and mix until paste forms. Dry the pork loin with paper towels and rub it all over with the seasoning paste. Then set it on a rack in a shallow roasting pan. Insert a meat thermometer on a slight angle into the very center of the roast.‎Herbed Roast Pork Loin · ‎Roast Pork Loin With Apricot ... · ‎Barbecued Pork Loin
Roasted Pork Loin Recipe - Allrecipes.com
allrecipes.com/recipe/21766/roasted-pork-loin/ Rating: 4.4 - ‎895 reviews - ‎1 hr. 20 min. - ‎238 cal
Directions. Preheat oven to 350 degrees F (175 degrees C). Crush garlic with rosemary, salt and pepper, making a paste. Pierce meat with a sharp knife in several places and press the garlic paste into the openings. Place pork loin into oven, turning and basting with pan liquids.‎Roasted Pork Loin Video · ‎Roasted Pork Loin - Printer ... · ‎Roasted Pork Loin Photos
boneless pork loin roast Google Search
https://www.porkcdn.com/sites/porkbeinspired/library/2014/06/2924.pdf
Dec 18, 2017 | Grilling
Beef tri tip roast in oven
Directions
  1. Rub roast all over with thyme, basil, marjoram, mustard, salt, and black pepper. Place meat in a sealable plastic bag, seal the bag, and refrigerate, 8 hours to overnight. ...
  2. Preheat oven to 450 degrees F (230 degrees C). ...
  3. Place meat in the prepared roasting pan.
  4. Roast in the preheated oven for 15 minutes.
Tri Tip Roast Recipe - Allrecipes.com
allrecipes.com/recipe/240779/tri-tip-roast/ Beef tri tip roast in oven Google Search
Dec 21, 2016 | Ovens
Braise chuck roast
Hmmm. Let's see. Place roast On high heat In pan and sear for a minute or two on all sides. Don't cover. After roast is browned, put in oven at 300 until cooked.
Mar 05, 2015 | Drills
Should I cover the round roast while baking in oven?
Initially you could but it cooks best in a dry heat without a cover
Oct 12, 2014 | Home
How to preparare a cooked ham using cloves
  1. Preheat the oven to 350 degrees F (175 degrees C).
  2. Place ham in a roasting pan, and press whole cloves into the top at 1 to 2 inch intervals. Pack the top with a layer of brown sugar. Pour enough water into the bottom of the roasting pan to come to a 1 inch depth. Cover the pan tightly with aluminum foil or a lid.
  3. Bake for about 1 hour in the preheated oven or until the internal temperature of the ham has reached 160 degrees F (72 degrees C). Make sure the meat thermometer is not touching the bone. Let stand for about 20 minutes before carving.
Apr 24, 2014 | Computers & Internet
What are roasting pans made from?
They can be made from aluminim foil (disposable pans), stainless steel, coated enamel, cast iron, or clay.
Jan 14, 2013 | Home
What is the difference between roasting pans and broilers?
Roasting pants are for big peicesof meat becuase they are big, deep pans so the meat will cook and be flavoured from its juice.
A broiler has shallow sides so the meat cooks faster. It also has a slotted bottom so the pan drains.
Jan 14, 2013 | Home
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Home Logo
    715 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
