Question about Razer Naga Expert MMO PC Gaming Mouse
Right click problem
When i hold down the right click fx in a game, it releases it and go back to holding it on. This happens every time.. I have tried to find sulutions on google, but without any luck. What should i do?
    Problem Solver:
  • 13 Answers
Search it on bing.
Posted on Jun 27, 2013
How do i copy & paste an email add to my email? For example, when replying to an ad on craigs list
hold down left click on mouse ,drag left to right ,text will change color , if more than one line required pull mouse down still holding left click down all text will change color, release left click ,right click and select copy with left click. Go to email left click where message goes,right click mouse and select copy with left click. Sounds involved but easy after a few tries.
Aug 10, 2014 | Computers & Internet
I have locked myself out of my tablet
You will need to do a factory reset:
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Hp officejet 6310 makes loud grinding noise on right side
1) connect the printer directly to wall
2) try different wall outlets
3) unplug the power chord and then press and hold down the power button for 30 sec. release the button.. then plug in the power chord
4) then try to move the carriage manually from left to right.
5) check if any papers or any thing is stuck inside the printer or not..
6) then unplug the power chord.. press and hold the pound(#) and no 6 key together and then without releasing the button plug in the power chord..once the power button in plugged in release the button..
the printer would go back to factory defaults..
check what happens
7) issue not resolved the service the product..
Mar 26, 2011 | Office Equipment & Supplies
My right analog keeps pointing down but im not touching it at all
im not sure what console your having this on... but I used to have it happen on my gamecube and n64 all the time. Try unplugging your controller and plugging it back in (or off then back on if it's wireless)
this often happens if your accidentally holding the thumb-stick down when you start your console/game
if this doesn't help you may need to either A: clean the controller or B: replace it
hope it helps
~good luck!
Mar 13, 2011 | Video Game Consoles & Games
Can't align head - used those instructions: 1) With the printer powered off, hold down the resume button and press the power button. 2) While holding down the power button, release the resume button and...
The following web page from canon support will help you do an alignment.
Click on the bottom of the solution list to pick your alignment options.
Click - Back to Ressult - upper right corner to get back to the solution list
you can then reselect a different option.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#ServiceAndSupport
Dec 27, 2010 | Canon PIXMA MX310 All-In-One Printer
How do you get past the ****** dam, where the wolves are chasing you, have tried everything
Cheats On the Press Start screen, input CROSS then hold L1 + R1 and input DOWN, DOW, RIGHT, UP. The Press Start message will turn green. During gameplay, the following codes and code effects may be input and activated:
Invulnerability ... Hold L1 and input DOWN, UP, DOWN, RIGHT, RIGHT.
Pevensie Kid Life Restore ... Hold L1 and input DOWN, LEFT, LEFT, RIGHT.
Accrue $10,000 ... Hold L1 and input DOWN, LEFT, RIGHT, DOWN.
Clear/skip current stage ... Hold L1 and input DOWN, LEFT, DOWN, LEFT, DOWN, RIGHT, DOWN, RIGHT, UP.
Unlock All Stages ... Hold L1 and input UP, UP, RIGHT, RIGHT, UP, RIGHT, DOWN.
If the code input is correct, the phrase Cheat Activated will appear. All codes may be toggled off by re-entry.
you can use the clear current stage trick..if you are fedup with your stand now...
Dec 23, 2010 | Buena Vista Games Chronicles of Narnia:...
Right Click Defected in-game
try switching the right click to another button using setpoint. if the button works perfect then it is the micro switch for the right click contact logitech. if it drops turn off setpoint and try the regular right click if that drops just may be a glitch in the game. check for mouse controls in the game to tune the mouse.
Jul 17, 2009 | Logitech G5
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Entering cheat odes
Cheat CodesUnlock All Levels:
From the Mission Select screen, enter code: Y, RB, Y, RB, X
Full Health:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: LB(2), RB, X, RB, Y
Unlimited Ammo:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: RB(2), LB, X, LB, Y
Scott Mitchell Invincibility:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: Y(2), X, RB, X, LB
Team Invincibility:
Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: X(2), Y, RB, Y, LB
Nov 29, 2007 | Microsoft Xbox 360 Console
Razer Naga Expert MMO PC Gaming Mouse Logo
89 people viewed this question
Top Razer Video Game Consoles & Games Experts
James Wishart
Are you a Razer Video Game Console and Game Expert? Answer questions, earn points and help others
