Question about Symbol Hotshot LS2106 Handheld
Symbol ls 2106 handheld scanners
While programming the handheld scanners, the scanners accept every barcode except for the scandata transmission format, which the scanner receives the lo\hi tone which means input error. I have repeatedly reprogrammed the scanners, directly from the manual even, but still not accepting the scandata transmission format. This is important as it allows hands free computing as the user does not have to press the enter key each time he/she scans in information.
  • Anonymous Mar 24, 2014
    get mac address for handheld devices (Motorola Barcode Scanners)
I cannot get it going on the pc with windows xp pro
Posted on Sep 14, 2008
SOURCE:
Symbol 4000i scanner will not scan barcodes that are single digit
Hello Jane Diaz,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for LS4000.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Oct 13, 2010 | Symbol LS 4000i Handheld
I need a default barcode to reset my scanner to accept barcodes automatically with my LS 4000I-I000 scanner
There is no such bar code. barcode scanner scans any barcode and give the result.
scanner can scan in any software. eg. excel,word. dos etc.
Aug 08, 2009 | Symbol LS 4000i Handheld
Scan a barcode and the help menu of the program. LS4000i
Disconnect the scanner from the mouse port or disconnect the mouse from the scanner. The scanner must be connected to the keyboard port and have a keyboard attached to the scanner.
Aug 05, 2009 | Symbol LS 4000i Handheld
Symbol ls 1902t-1000
You need to set up the scanner -- if you don't have a manual, you can download one from http://support.symbol.com/support/supportcentral/supportcentral.do?id=m1 Then, call Symbol Support at 1-800-653-5350 and they'll talk you through it.
Cheers
Billy Barcode
Jul 18, 2009 | Symbol Open Box Cobra LS 1902T...
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Automatic RETURN/ENTER ...
I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
http://www.intermeccorp.com/pdf/2106setup.pdf
May 13, 2008 | Symbol Hotshot LS2106 Handheld
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
Decodeing UPC-A Supplemental 2 or 5 code
you should have a code book that came with the scanner, the code book allows you to program the scanner's options, the code book takes you step by step through the programming proccess. each option requires you to scan varios barcodes to "set" the various options one of the options will be to set the barcodes you wish to use, this is set to avoid a misread (confusion between barcode standards)
Aug 07, 2007 | Symbol LS 4000i Handheld
Symbol Hotshot LS2106 Handheld Logo
633 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
