Question about Brodit ProClip for Renault Trafic 2002 - 2010 Angled mount
P062f - Brodit ProClip for Renault Trafic 2002 - 2010 Angled mount
2009 Cadillac dts cracks but won't start
Cranks but won't start , cracks ! that's funny ,sorry ! Are there any lights lit on the dash , SECURITY etc.....
Engine Cranks But Does Not Run
Circuit/System Description
This Engine Cranks but Does Not Run is an organized approach to identify a condition which causes the engine to crank but not start. This diagnostic directs the technician to the appropriate system diagnosis.
This diagnostic assumes the system voltage levels are adequate for starter motor operation. Refer to Battery Inspection/Test , and Engine Cranks Slowly . Fuel level and fuel quality should be determined for correct diagnosis.
Special Tools ?€¢
CH-48027 Digital Pressure Gage
J 26792 HEI Spark Tester
Crank the engine for up to 30 seconds. Observe the Engine DTC information with a scan tool.
If any of the following DTCs are set, refer to Diagnostic Trouble Code (DTC) List - Vehicle to diagnose those DTCs P0201-P0208, P0230, P0335, P0336, P0340, P0403, P0404, P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, P0641, P0651, P0685, P0689, P0690, P1516, P2610.
Ignition OFF for 90 seconds, determine the current vehicle testing altitude. Ignition ON, observe the scan tool MAP Sensor parameter. Compare the parameter to the Altitude Versus Barometric Pressure table. The MAP sensor pressure parameter should be within the specified range indicated in the table.
If the reading is not correct for your altitude, diagnose the MAP sensor. Refer to DTC P0106 .
Install a J 26792 . Crank the engine for 15 seconds. Spark should be observed from the Spark Tester.
If spark is not observed refer to Electronic Ignition (EI) System Diagnosis .
Important: Additional DTCs may set when using the fuel pump output control.
Command the fuel pump ON and OFF. Fuel pump should energize when commanded ON and De-energize when commanded OFF
If the fuel pump does not respond refer to Fuel System Diagnosis .
Turn OFF the ignition. Install the CH-48027 . Turn ON the ignition and command the fuel pump ON while observing the CH-48027 . Refer to Fuel Pressure Gage Installation and Removal . The fuel pressure should be between 384-425 kPa (55-61 psi).
If the fuel pressure is not within 384-425 kPa (55-61 psi), refer to Fuel System Diagnosis .
Inspect for the following conditions:
Compare the actual engine coolant temperature to the ECT parameter.
Air filter and air intake system for restrictions and obstructions
Test the fuel for contamination. Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
Inspect the spark plugs. Refer to Spark Plug Inspection .
Test the exhaust system for restrictions. Refer to Restricted Exhaust .
Engine mechanical conditions such as worn timing chain gears, low compression, etc.--Refer to Engine Compression Test .
Sep 14, 2015 | Cadillac Cars & Trucks
Battery saver comes on battery light wont start like low battery started 5 min before code p062f comes up
Since you give no make , model or year of vehicle, I will assume it is fairly new if it has a battery saver feature. New cars are programmed to shut down non essential components to conserve power to start a vehicle that has marginal voltage to start the engine. Seems your battery is dying and your car is warning you that it may not start if the problem is not attended to ... Have your electrical starting system checked. Battery alternator, and load check.. Replace battery or alternator if needed.
Feb 12, 2015 | Cars & Trucks
I got a code P062F on my 2012 Chevy Equinox LS. What does that mean?
Powertrain-Internal Control Module EEPROM Error
Possible Causes
  • Engine Control Module modified (e.g. Chip Tuning)
  • Engine Control Module faulty
Possible Solutions
  • Contact your Tuner ;)
  • Replace Engine Control Module
Nov 01, 2014 | Cars & Trucks
P062F = Internal Control Module EEPROM Error
new battery and if the car sits for a day the battery is dead
Apr 29, 2014 | 2012 Chevrolet Impala LS Sedan 3.6L V6 FFV...
Error p062v
dont recognise those codes follow this link may help
OBD Codes Site Map
Mar 27, 2014 | 2012 Chevrolet Equinox LS 4dr SUV 2.4L...
Code po62f
The TCM monitors itself by using a watchdog circuit and by various software monitoring functions. If there is a fault,
a P0613 is stored. The flash ROM is checked using a checksum calculation. If the checksum is incorrect, a P0605
fault will be stored. The EEPROM is emulated in the flash ROM. If it is not possible to store information in the
EEPROM emulation or if the verification fails, a P062F fault is stored and the ECM is requested to illuminate the
MIL immediately. If the diagnostic software tries to enter two contradictory failure mode strategies or if there are
contradictory output states commanded versus the expected output states, a P0701 fault is stored. It's time to visit the Dealer.
Jul 14, 2013 | 2006 Chevrolet Cobalt
Error code p062b 2012 equinox
Had the same problem on our 2012 Equinox today. Threw codes P026B and P062F. Appears to be a bad battery. Replaced battery and all seems ok now...keeping fingers crossed. My suspicion is that the faulty, dying battery caused a low voltage situation in the injector control module and thus those errors. Will see if the check engine light returns in the next 48 hours.
Apr 20, 2013 | 2012 Chevrolet Equinox LS 4dr SUV 2.4L...
My 2007 chevy hhr is giving me check engine code P062F. What does it mean? How do I fix it?
P062F = Internal Control Module EEPROM Error = the memory chip inside the ECM has been fried. You will have to replace the ECM.
Mar 30, 2011 | 2007 Chevrolet HHR Special Edition
Brodit ProClip for Renault Trafic 2002 - 2010 Angled mount Logo
74 people viewed this question
Top Brodit GPS Experts
Jeff Hogancamp
Jeff Hogancamp
Tim Rickards
Tim Rickards
 Russ Hill
Russ Hill
Are you a Brodit GPS Expert? Answer questions, earn points and help others
