Question about Brother MFC-7340 All-In-One Laser Printer
Error message Whenever i start my machine i get a self diagnostc will restart in 15 minutes then i keep getting an print unable 6F error message whenever i try to print or copy on my machine
    New Friend:
  • 4 Answers
Copy on my machine then i tray to copy
Posted on Jun 02, 2013
Mix-it-up
  • 832 Answers
SOURCE: Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Posted on Sep 10, 2007
Mix-it-up
  • 832 Answers
SOURCE: Unable to print, unable to int, unable to clean
unable to clean is the error 46. You have to change the waistinktank and to reset the error code: Buy/order a new waistinktank from a service partner (see brother homepage). Open the printer (use pictures to know how to): http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c The waistinktank (ALTTINTENTANK) is the plasticcover with the white felt in it (should be gray/black now) and the two tubes (gray/white). Unplug the tubes and change it to the new one. Reassemble the printer. After power up press menu then start mono (B/W) then 4 times arrow-up: maintenance should be displayed and printer beeps with flashing buttons. Press 8 and 0 (zero). Press severaltimes (about 15-20) start mono (b/w) until purge (Nummer is about 6425) is displayed. Press 2 7 8 3. Purge is 0000. press stop. press 99. machine comes up again. thats it. BTW: YOu cant clean the waistinktank. Buy/order a new one! If you reset the purgecount without changing the waistinktank ink will flow into the machine!!!
Posted on Sep 18, 2007
bono1
  • 32 Answers
SOURCE: Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Posted on Dec 09, 2007
komguy
  • 2306 Answers
SOURCE: Print unable 32 ?
Print unable 32 is dirt or scratch on the transfer belt assembly. There's a timing mark on the belt that a sensor must read. If the belt is damaged, you will need a new one.
Posted on Aug 07, 2009
SOURCE: Unable to print 36
lift the lid to where the connections cable is
I have had this problem several times & this is the only fix
Posted on Feb 02, 2010
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
WARRANTY AND SERVICE OPTIONS.
Brother Authorized Service Center locator
Jan 12, 2018 | Office Equipment & Supplies
I have an HP photosmart 3310 printer with an error message: INK SYSTEM HAS FAILED. UNABLE TO COPY, RECEIVE FAXES, OR PRINT. REFER TO PRINTER DOCUMENTATION. ERROR: 0xc18a0106 This comes on whenever I...
Why dont you try uninstalling this form your PC/laptop and reinstalling it again.
This should help restart the printer again.
Good luck and thanks for using Fixya
G.
Jun 14, 2011 | HP Office Equipment & Supplies
Whenever I try to print something it says "unable to print 36". Ive restarted the printer and tryed to print something and for a couple of minutes it says cleaning then a few minutes later it...
Remove the printer cartridge and check for any jams. If you don't see any large pieces of paper jammed in the printer, they may be smaller pieces so take care to notice anything small that shouldn't be there.
Place the cartridge back into the printer.
You may also want to unplug the power, wait a moment and plug it back in to clear the error and see if the issue corrects itself.
Mar 02, 2011 | Brother MFC 490cw Color Inkjet...
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
My nokia 5800 shows unable to perform bluetooth operation whenever i switch on the bluetooth.
I have Nokia5800, which causes an problem regarding bluetooth.whenever i start bluetooth it show me an error message "unable to perform bluetooth operation"
Oct 25, 2010 | Nokia 5800 XpressMusic Smartphone
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
Error Message appear when printin
It is almost two years i started using this printer but recently whenever i;m printing with this printer, i get a report; " Cam Platten Error" and my document fails to print. Please help me.
Mar 15, 2008 | Hi-Touch Imaging Technologies HiTi 730PS...
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
Brother MFC-7340 All-In-One Laser Printer Logo
151 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
