Question about Electrical Supplies
All of the 3 lights on the gc9220 are flashing in sequence, the iron has turned itself off so not working - why is this and what do I need to do to fix?
TV turns itself off and power light flashes green
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
ONLY FLASHING THE GREEN LIGHT, THE DIVICE POWER OFF BY ITSELF WHEN IS NOT USING. MAYBE I FORGOT TO TURN ITOFF. BUT NOW IT DOESNT WORK. PLKEASE NEED HELP. DVD AUDIOVOX AXDVD2002.
The flashing code is a trouble shooting guide for the techs, you have lost something either in the power supply or another board in your unit. Depending on the sequence of the flashes tells us what to look for. Is this a TV or dvd player?
Mar 07, 2011 | Televison & Video
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
Jan 26, 2011 | Tefal Pro Express GV 8120 Iron
I have a Sony FD Trinitron WEGA KV-27FS120 the Standby light flashes four consecutive times with a pause in between sequences. When I turn the TV on with the remote, it powers up, you have volume but no...
It is vertical deflection failure problem.
Let me know if you want to repair TV by yourself, that requires soldering parts in PCB experience.
Aug 08, 2009 | Televison & Video
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
How does the ready light work on the toasymaster waffle baker
Depending on what you have it should turn green when ready to cook, ten the light shuts off when you put the waffle mix in then when waffles are down it turns green again
Feb 07, 2009 | Toastmaster Kitchen Appliances - Others
Its gone off!
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Dec 27, 2007 | Rowenta Perfect Iron
Electrical Supplies Logo
99 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
