Question about HP LaserJet Pro 400 color MFP M475dn
Hard reset m475dn - HP LaserJet Pro 400 color MFP M475dn
M475dn 1 Answer Error 59.CO on Hp laserjet pro 400 color MFP M475dn
The product has experienced an internal embedded software error. Under most conditions, the product automatically restarts.
Sep 27, 2017 | HP Office Equipment & Supplies
I Purchased NEW THIS PRODUCT HP LASER JET PRO 400
default must be no password , here are the steps to reset the printer
NVRAM reset for the HP LaserJet 400 colorMFP M475dn (Confirmed functional) 1: Print configuration page before beginning reset
2: Disconnect all cables except for power
3: While printer is in ready state, note the position of "Ready" message on the screen (Probably bottom right)
4: Power off the printer via power button
5: Touch the location on the screen where "Ready" message appeared.
6: while touching the screen, power on the printer. Continue to hold the screen.
7: When "Memory Limit Reached" message appears, release the screen.
8: Printer will reboot, clean and calibrate
9: Return cables to their appropriate ports
10: Print configuration page to confirm settings are cleared. Restore settings desired manually.
Finally have access back!
Mar 08, 2017 | HP Computers & Internet
How to switch from number pad to letter pad on my HP printer M476DW
If you want technical support of HP, you can contact us on HP Printer Tech Support Phone Number 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/jhx3XY
Apr 21, 2015 | HP LaserJet Pro 400 color Printer M475dn
M475dn paper torn in duplex, how can you get it out
First you want to make sure that you remove the paper in the normal direction of travel to avoid damaging sensors. Try to find either a thin stiff piece of cardboard or plastic, like a store loyalty card and push that through in the direction of travel to push the paper out. Be very cautious about using any type of knife or metal object because if you break any plastic guides or scratch the plastic inside the ADF it might lead to future jams. I typically recommend that customers scan perforated items off the glass not through the ADF.
Sep 15, 2014 | HP LaserJet Pro 400 Color MFP M475DN...
Laserjet pro black vertical lines using adf
Do regular prints look ok? If so, then try copying something from the flatbed glass. If that copy has no line then you have something on the glass where the paper passes over when fed through the adf, clean the glass well, you may need to use some rubbing alcohol because often fine bits of adhesive from things like sticky notes will cause the lines but are not obvious to the eye when you inspect the glass.
Jul 31, 2014 | HP LaserJet Pro 400 Color MFP M475DN...
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
HP Laser Jet Pro 400 MFP M475dn
Neither. I suspect your system may be in bad need of a cleanup.
Online virus removalWindows8Blog
Feb 04, 2014 | HP Computers & Internet
Hard reset lg e739
LG E739 hard reset
LG T-mobile myTouch E739 reset If you can't recall your unlock Pattern:
When the phone is turned off, press and hold the Power/Lock + Volume Down.
After 3 seconds press
Back and Menu keys.
WARNING: If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to back up any important data before performing a Hard Reset.
Source: http://www.hard-reset.com/lg-e739-hard-reset.html
Jan 15, 2014 | Cell Phones
HP LaserJet Pro 400 color MFP M475dn Logo
64 people viewed this question
Seeker5211
Seeker5211
