Question about Venturer PVS177W Portable DVD Player
Not reading after inserting disk appears with 'no disk'. this disk has been used before
Disc inserted but NO DISK message appears
Try other discs to see if its still working properly...most likely the recording on the disc is not burnt properly or there's something wrong with the disc, (ie, scratched or surface dirt etc) or the DVD player just can't read the disc...for example can it read the type of disc(does it read dvd+r or dvd-r, or both?--- if i remember rightly)..... I've had discs that have had bad recordings but can still be read if placed into tray a particular way around... randomly try different positions, also cleaning disc as you go...depending on how desperately you want it to read the disc...could also be bad disc batch... there could be many reasons...
Sep 22, 2012 | Televison & Video
Cd changer cannot read cd
Its laser pickup assembly might be faulty. Click here to know more about how to clean it. Do it once, and if it do not help you, replace it with same type and number.
Sep 03, 2012 | Audio Players & Recorders
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
I cant play the game an error says No disc inserted. Please insert the original "NBA2K11_EU" CD/DVD
Does your CD/DVD reader successfully read any *OTHER* CD/DVD disks?
If not, it is broken, and needs to be replaced.
If the drive works, then Insert the original 'NBA 2011' CD/DVD disk, when prompted.
Jun 08, 2011 | Computers & Internet
Hi! I inserted a burned dvd r into my Mac but it's not reading it. The message You've inserted a blank CD pops out. I tried using a PC but it can't open it either, it says there's an error...
there are a few reasons why
1.) the formatting of the disk may be formatter for a PC and NOT a MAC
2.) after burning, this dvd was never "closed"
3.) You burned a coaster
good luck
Jun 06, 2011 | Computers & Internet
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Hi - When I insert a gaming or music disk into my PS3 it makes a noise as if it wants to eject the disk again. This either happens or otherwise it wont recognize that a disk has been inserted. This...
Hello, It's possibly lens calibration problem, sometimes that happens when there's a lot of sudden movements during transportation, sometimes the use of scratched disks tend to trigger the Error correction algorithm of the PS3 reader, putting the reading lens into a lot of stress that heats up the EC chip and games are not read properly, causing the game to fail loading and making unusual sounds.
I recommend not to use scratched disks, try to use only PS3 game disks only to extend your console's life, and take good care of all your disks, keep them clean.
The thing is as technology improves Disks format changes to put more information into a single disk, and precision looking for data is more critical as data sectors are closer to each other, so scratched or dirty media tends to return errors.
Hope I helped, and try to seek some professional help on calibrating/substituting your old reader.
Apr 28, 2011 | Computers & Internet
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 24, 2010 | Sony Bravia DAV-HDX265 Theater System
Dvd external trouble : i have dvd lightscribe supermulti DVD RW, hardware can operated normally, i can hear souding from drive motor wen inserted a disk, but next appear box contain Please Insert a Disk,...
there ll be a lens in dvd writer which ll be corrupted and disk ll rotate properly even if lens of the dvd writer is spolied...
u hv said u hv warranty right do register for a replacement of the dvd disk
Jul 09, 2009 | Computers & Internet
Insert a disk
How many CDROm drive installed on your PC? The message appear when you burn a CD or just only reading the content?
Mar 02, 2008 | Samsung SM 352 CD-RW/DVD-ROM Burner
Venturer PVS177W Portable DVD Player Logo
20 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
