Question about Lenovo ThinkPad T400 PC Notebook
Critical low battery error - Lenovo ThinkPad T400 PC Notebook
My Kindle won't charge
If the battery isn't too far gone, here's how to revive it: Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored Kindle. If not, go on to step 2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
How To Restore Your Kindle If It Experiences Critical Battery Error
f you can't get past step 3, the battery might be too far gone. Contact Kindle customer service via phone (866-321-8851) to walk through extra troubleshooting steps. If they can't revive it, Amazon will usually replace the eReader for free. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
Aug 06, 2015 | Amazon Kindle 1
If it is an error, remove the battery monitor from device manager and when youreboot, it will install a fresh one ... hopefully with no errors!
Dec 13, 2013 | Computers & Internet
0190 critical low battery error
push the power button at the same time with thinkpad button, and fast press F1 key.
you should need to do this 3 times to fix the problem.
May 14, 2011 | IBM ThinkPad T20 2647 Notebook
Canon PowerShot A530 Digital Camera My problem is everytime I insert new battery in my camera the indicator is always low battery... And when I turn it off and on again sometimes full battery.. Is there...
Hello
If the batteries are indeed new batteries and you are continuing to get this low battery warning, there is a defect within the camera. However, it may or may not be critical.
Test out a new set of batteries, if they last you a typical amount of time, the error is a false reading and can be ignored. However, if the batteries drain at an advanced rate, there is a short in the camera and it will need to be sent in to Canon for service.
Mar 19, 2011 | Canon PowerShot A540 Digital Camera
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Bought a new ac charger for the laptop and tried to charge it up ,critical low battery error keeps coming up and computer switches off
replace battery, as long you adapter plug in indicator work charging also work so only battery not accept charging.
Apr 04, 2010 | Lenovo ThinkPad R61 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
"Critical Battery Error" even with not battery in laptop
Do you have another power supply to use?
Also, is it keeping correct time and date?
Dec 14, 2007 | IBM ThinkPad T20 2647 Notebook
Lenovo ThinkPad T400  PC Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
