Question about Nikon Coolpix 4600 Digital Camera
Red hand symbol is flashing on the view screen
When I ahve my camera in the picture mode , a red hadn is flashing in the right side of the screen.It is not there for other modes except the panaramic. What does this mean and how do I get rid of it. I cannot get a good picture in these modes either, they are all blurred,however the action mode is fine. Thanks for your help
  • skylandsmama Aug 16, 2007
    how do I adjust the shutter speed ?
    Thanks in advance
    never mind, hubby turned off BSS, which sloved the problem
    President:
  • 1,114 Answers
This is the sign warning you that the shutter speed is slow so camera shake is a problem. It means use a tripod or support the camera because holding by hand will cause blurred pictures that you see. When you see this sign you can either try to get more light on the subject or support the camera. This sign will also come on the low light conditions. Look at the shutter speed & you will see that this symbol will appear when it falls to about 1/60th of a second. Using a tripod is the best idea especially for a panoramic shot as when it is on the tripod you can turn the camera through 180 degrees taking overlapping shots then "stitch" them together in Photoshop or whichever software you use to create a single large panorama. If you don't have a tripod then put the camera on a wall or lean against something to give you more support. Good Luck!
Posted on Aug 10, 2007
  • Greg Cann
    Greg Cann Aug 15, 2007
    I have given you the correct answer and what to do to prevent it.
    Below is the paragraph from the manual that backs up what I say.
    Please rate this answer as solved.
SOURCE:
Turn off flash
With the camera ready to shoot in Auto mode - you will see a little lightening symbol in the top right hand corner of the screen. This indicates the flash is turned on.
On the left side of the circular dial at the back of the camera you will see a similar little lightening symbol indented into the dial. Simply press on this side of the dial to turn the flash on or off as you desire.
The symbol on the screen will go off when you push this to indicate flash is off and return if you press again to turn it on.
Thanks for using FixYa.
Dec 30, 2009 | General Electric A950 Digital Camera
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
Red hand blinks on screen upper right side. how do i deleet this problem. nikon coolpix 7500.
The red hand icon flashing shows that the camera is using a slow shutter speed, and is a warning to be careful to hold the camera steady.
You could put the flash in auto mode and it will fire when the light is low.
Jul 16, 2009 | Nikon Cameras
Pictures are blurry
this is a symbol for a low light condition. Either increase the light by opening curtains using in-direct light or just use a flash.
Nov 30, 2008 | Canon PowerShot A620 Digital Camera
Taking pictures
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
Olympus sp 350
There is a "quick" button located on the back of the camera just for flashes. It is the first button to the right of the power button and it looks like a crooked lightning bolt arrow that points down. If you are in any picture taking mode, push this button and it will toggle you through each flash option, auto, red eye (eyeball symbol), flash (same symbol as the button, this mode will make the flash work everytime you take a picture), red eye and flash, and no flash (careful, in this mode you have to allow for the camera to focus, the lens will stay open a long time in a dark atmosphere -- if you don't hold the camera still you will get a blurry picture).
Apr 09, 2008 | Olympus SP-350 Digital Camera
Won't take a picture
I work on these cameras all the time you have a ccd going out or has gone out that is causing the auto sensing feature to now work their for the camera stops working. 1 other thing it might be could be the main-board but they don't go out as often.
Mar 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Camera turns off
the red symbol is the erasure prevention slider on the tape. check it's not on or push the slider on and off prevention. this should fix the red symbol, you might have to do it a couple of times before it works. not sure what F14 is can't find it in the manual. try the solution here. if it still turns off after a few seconds i have another way to fix the power.
Nov 04, 2007 | Panasonic NV-DS65 Mini DV Digital...
Nikon Coolpix 4600 Digital Camera Logo
418 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
