Question about Sony Handycam DCR-TRV6 Mini DV Digital Camcorder
Sony dcr-trv6 unable to load tape in deck
Sony dcr-trv6 camcorder unable to put tape inside deck because it beeps and shows c:31:30 on lcd screen.
  • 38 Answers
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Posted on Aug 12, 2007
I have a Sony Handy cam DCR-HC30. When i put a cassette in, it says (reinsert the cassette).
-make sure that your tape is clean and dry
-clean the tape head inside the tape deck if you have a video head tape cleaner
*tape head: the one that reads the tape inside the camcorder.its the metal thing at the bottom inside the tape deck.
-or you can use a soft and dry Q-tip to clean it(dont use any liquid cleaners)
*or if confused where the tape head is....just clean all metal parts inside the tape deck and make sure you do it lightly with a soft dry Q-tip.
Jun 05, 2011 | Sony Handycam DCR-HC30 Mini DV Digital...
No image on the LCD screen - handycam SONY DCR-HC19E PAL
I have a Sony Handycam DCR HC21. The LCD stopped showing after I put a new tape. I then put the old tape in and nothing change. May I have it a button
Jan 10, 2009 | E.Digital DCR-PC106E DIGITAL CAMCORDER
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-trv6 shows c:31:30 and beeps
the capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Sony dcr-trv6 beeps and shows c'
check the capstan motor if it is stuck up... find if there some debris inserted at the sensor...if nothing you find check also the bushing in the upper part of the motor
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Sony Handycam DCR-TRV6 Mini DV Digital Camcorder Logo
173 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
