Question about Autodesk AutoCAD 2010 Full Version for PC (001B141A1111001)
Code activation activation code missinf from computer
  • 542 Answers
Contact software manufacturer or distributor and they will assist you, otherwise the serial number should be with the paperwork that came with the software.
Posted on May 08, 2013
I purchased a turquoise nightstand from Wayfair and some parts are missinf
not a problem for fixya site
take it back to where you got it and complain to them
May 23, 2017 | Furniture
How do I reach this special page to ?get the activation code on.
Windows activation or validation fails and may generate ...
https://support.microsoft.com/en-us/kb/921471
Microsoft CorporationDiscusses that activation or validation fails and generates error code ... Level: Error Description: Acquisition of Secure Processor Certificate failed. ... To do this, follow these steps for your version of the operating system. ... Volume Activation error codes on Windows Vista-based computers ... Get help with activation errors
Standalone Product Activation FAQs - SOLIDWORKS
https://www.solidworks.com/sw/.../1090_ENU_HTML.htm
SolidWorksWhat does SOLIDWORKS do with the computer-specific information sent during the ...Does product activation make the software harder to use? ... number which is then down sampled to reduce the size of the activation request code. .... name, version, and language; and your computer's processor and hard-disk type.
Activation Keys and Serial Numbers
georeference.org/doc/activation_keys_and_serial_numbers.htm
Jan 09, 2016 | Computers & Internet
I have a key missing. I wamt to change ignition so the missinf key cant be used. How so I do this.
I think you need to speak to a dealer because there may be coded inputs needed to match a new assembly to the cars electronics. If there is no coding needed then a local garage can do it if its just a lock swap but remember the door locks as well. Most cars have the same key for both. This makes it a costly and expensive job. Change the ignition lock but it won't fix the door problem.
Apr 27, 2015 | 2001 Lincoln Navigator
Corrupt or missinf file windows/system32/config/system what can i do
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or if these fail to resolve the problem
hope this helps
Feb 07, 2011 | Gateway Computers & Internet
Howto get a code for a Sony Blue ray
First you must have your netflix membership. Afterthat Netflix give you a activation code.
Laptop /pc
1. You have to signup for netflix then sign in your account with your e-mail i.d. & passowrd.
2. Sign in your account then click your Account & Help
3. You see lots of details of your plan then you see these options.
WATCHING INSTANTLY ON YOUR TV OR COMPUTER
* Activate a Netflix ready device( click this)
* Follow the instructions on your device to get an activation code.
* Your computer and device must both be connected to the Internet to activate.
You can see the activation code on netflix( TV).
then enter this activation code on netflix account.(PC-NETFLIX ACCOUNT).
May 31, 2010 | Sony Computers & Internet
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Need the shank the feet fasten on one of the holders is missinf
try to google the manufacturer and order one online
Dec 11, 2009 | PfaFF Creative 7570
Missing advrcntr2.dll
Read here:
http://www.castlecops.com/p977915-Missing_files_Program_requires_advrcntr2_dll_Photoshow.html
Also, this looks like a source for that .dll which isn't suspicious or requires lots of form-filling:
http://www.dll-files.com/dllindex/pop.php?advrcntr2
However try the advice from the castlecops thread first. If you can solve the problem without just adding a .dll file hap-hazardly, that's probably the better route to take.
Mar 17, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Autodesk AutoCAD 2010 Full Version for PC (001B141A1111001) Logo
26 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
