Question about HP DeskJet 5550 InkJet Printer
Hp 5550 blinking
I have an Hp 5550 inkjet and when I turn it on all the light s come on and the paper feed and power lights blink at the same time. What is the deal?
  • 4 more comments
  • DAve-o- Aug 13, 2007
    No it does not work
  • sharkied Nov 27, 2007
    my machine jammed as a label was printing - I removed the paper and no part of it stayed behind, but the power & resume lights continue to blink. I tried all the paper jam steps and even replaced both the ink cartridges, just in case, tried powering off and disconnecting from computer and redoing all - still have both blinking! Help!
  • Anonymous Jan 07, 2008
    Same!
  • NormaO May 19, 2008
    I was printing photos and a paper got stuck. I pulled the paper out and the two lights (pager & power) began to blink. I have powered down the printer, reset, etc. and it still won't print. What do I do?
  • Anonymous May 28, 2008
    hp deskjet 5550 priters problem.on & off light &paper feedind light are continuasly blinking.plz.replay me what is the problem
  • RAIDER33 Sep 23, 2008
    The lables jamed I pulled them out now the front two lights won't stop blinking
Like the post above, take both cartridges out of the printer and close the lid. The printer should start to activate the printer arm. Then once the printer is done moving replace the cartridges and close the lid. Press print!
Posted on Jan 07, 2008
Remove the 2 ink catridge and cover it back you will see only catridge error light peeping. off it and on it back then put the 2 catridge back i hope this will solve your problem. from .
Posted on Sep 26, 2007
Also clean the printer rod where cartridges after doing the above solutions.
Posted on Sep 22, 2008
Taking off the catridge, it works... thanks
Posted on Sep 19, 2008
SOURCE:
I have hp deskjet 5550 printer,when i was trying to print a document there is no print out, two lights are blinking
Hi, This could be Low-Ink or paper Jam. Try turning off The printer, Unplug from The Mains Electric, for 3-5 Minutes. Turn back On, if Lights Are Still There. Check The Ink-Levels. And Replace Cartridges, if necessary.
Mike.
Jun 02, 2011 | HP DeskJet 5550 InkJet Printer
I can't print and I have an orange flashing light on the right side of the printer. Whay does this mean?
Issue: The Power light is on and the Resume light blinks
In this error condition, the following light pattern displays on the product control panel:
•Print Cartridge status light : Off
•Resume light : Blinking (orange)
•Power light : On (green)
Causes
??¦The product is processing a print job, or waiting for the ink to dry on a document.
??¦The product might be out of paper.
??¦The product might have a paper feeding issue or a paper jam.
There are several possible solutions. To work through these suggest you follow the illustrated on-line guide found here.
Jan 16, 2011 | HP DeskJet 5550 InkJet Printer
Hp 5550 deskjet not printing
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
If this not help your printer has problem in carriage unit and need repair.
Nov 04, 2009 | HP DeskJet 5550 InkJet Printer
Resume and power lights blink all the time
HP has an excellent online support site with detailed instructions to help you clear this error. Click here to see them.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 06, 2009 | HP DeskJet 5550 InkJet Printer
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Paper feed problems
tha only thing that you need to do is to put just a little oil in the bar that spends the cartidges not too much, this with the printer turn it off and moving with your hand slowly the carrier and puting at the same time the oil.
then turn it on the printer and then live it to do alone his own functions, and that`s it
regards
Nov 13, 2007 | HP DeskJet 5550 InkJet Printer
Blinking Light
uaually the LED blinnks when there is no ink or when it runs low on ink. But since the LED is kept there to indicate any error happens to the printer.... 1. So I suggest that you should take out the printer cartridges and check all of them....shake well before you put it back. Now open Control panel - printers and fexes - right click HP 5550 - Properties There should an option to see the ink levels. If you can see the ink levels....it means that printer can detect the cartridges. Now the printer LED should be turned off. If the above doesn't work, try this; Check the printer que .. if there are print jobs pending, the LED will blink. Delete the print jobs, and restart the machine. This should solve your problem.
Oct 02, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
999 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
