Question about Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-W5. Will not turn on.
I have a Sony Cyber-shot DSC-W5. It has given me a very good reliable service for many years. Yesterday, despite fully charged Sony Ni-MH batteries, I found I could not switch on the camera. This has never happened before. Can you please help.
  • kaft Apr 06, 2009
    Mine did the same thing to me this weekend.  It wouldn't turn on.  I charged the battery and it still won't turn on. I have had it for maybe 3 months.
    New Friend:
  • 6 Answers
I have the same camera,bought in 2006, doing the same thing, with new batteries would turn on and immediately turn off. I had had experience with electronic devices that had overloaded capacitors.
So, I took the back off, took the screws out that held the main parts in the case so I could see the two leads on the capacitor.
Using a WELL insulated screwdriver help with WELL insulated pliers, shorted the two leads. The resulting bang scared my wife and the dog! I jumped these leads several times, each time getting a much smaller discharge until there were no more. Iput it back together and installed new bats. It was the same as before. I switched the bats, Put them in the WRONG way, help down the "on" button for 30 seconds. Put the batteries in the right way, and NADA, nothing. kNOWING HOW CAPACITORS WORK, I removed the bats and let the camera sit (no batteries in it) overnight. After lunch the next day I put the batteries in AND it worked just like new! To make sure I took a 45 minute video (VGA). I had a DSC-W3 before that had acted the same way, repairs were done the same way, and then sold the camera, Last time I checked it was still working after 4 years.
Posted on Jan 25, 2015
  • 294 Answers
Try diffrent batteries even the ni-mh batteries go bad after so many charges also make sure you have the batteries in the right way
Posted on Apr 05, 2009
SOURCE:
How to reset sony dsc-w5?
  • To reset turn off the camera and remove the battery. Hold down the power button for 15 seconds then release. Reinsert the battery pack and power on the camera.
Feb 25, 2015 | Sony Cyber-Shot DSC-W5 Digital Camera
I Use a fully charged(more than 14 hrs charged) New Sanyo battery 2700 mAH Ni MH rechargeable on my Sony Cyber Shot DSC-W5 Digital camera, when the power is on the battery display shown fully...
may be batteries you brought are old try with normal ( not rechargeble ) batteries. it would not last long but you can take atleast 30 to 50 photos. if it works it means new batteries are faulty.this type of problem i never saw in camera.use SANYO harmolattice HR-3UQ batteries.
Jun 22, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony DSC-W5 camera and the LCD screen is blank (white)
Remove the Battery pack from the Camera then press and hold the power button for 30 seconds.
Next, reinsert the Battery pack in the Camera and try to turn it ON. Make sure that the Battery pack is fully charged. If the LCD remains white then the LCD screen needs to be serviced or replaced.
Nov 25, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-Shot DSC-w5 "MEMORY Stick LOCKED" ??? please help!
take your memory stick out of your camera and theres this sliding thing on the back...slide it so that its not on the lock side? does that make any sense? well..good luck!
May 11, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Use of batteries in digital camera
you can change from nickel metal hylide to lithium ion batteries but you need a lithium charger. DO NOT SUBSTITUTE chargers! I've had my sony mavica for 7 years I have not needed to change the flashtube. the flashtube is a xenon based flashtube.
Nov 29, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Urgent-shuts itself off
Hello, please try to replace the batteries with freshly charged ones (NI-MH). If this does not help you can contact me at LIVE session. Best regards, Arpi
Jun 17, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Power shuts when in camera mode
The user manual would not be of much help. Please try to clean the battery contacts inside the camera. Please use the new fully charged NI-MH accu batteries preferably 2500 maH capacity. If this measures do not provide a cure please contact the nearest Authorized Sony Service. If you need more info please advice.
Apr 10, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Sep 08, 2005 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
465 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
