Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Xm2go Turned unit on this AM. Display page came on(XM2go logo) but unit has remained stuck in that position. I cannot tune the unit or even turn it off at this point. Appreciate any thoughts, help, tips. Patt312
  • Anonymous Sep 23, 2008
    I have the exact same problem. I purchased a new battery and the unit is still stuck on the xm2go screen. I have to think it is DOA at this point. Odd thing is, it was never dropped or damaged. I moved and did not turn it on for months, but that was it. Neat device but only lasted 1.5 years. Let me know if you figure it out.
  • pazazz Nov 29, 2008
    I have the exact same problem. I thought it might be the battery, but it wasn't. Hope help is on the way.
    pazazz
It occured to me after plugging it into the car adapter and turning on the car ignition. I ended up sending the unit to Panasonic and they sent me another. This must be a known issue.
Posted on Oct 17, 2008
Pioneer Inno - Powers on, great signal - but audio or pad data!
I'm assuming the power button it not in 'hold' position, and you have the volume turned up, and/or on the correct frequency with the adjoining radio?
May 27, 2010 | Pioneer XM2go Inno Satellite Radio...
Xm2go is not receiving
Did you try removing the battery to reset the unit?
Feb 27, 2008 | Tao XM2go Satellite Radio Receiver
I would like to connect my antenna directly to my XM2GO unit without the docking station. Where can I find an adapter?
Simple. Go to http://xmfanstore.com , click on "Antennas and Extensions" under "Shop Categories" on the left most side of the site; there you will find "XMFanStore XM2go Direct Connect Antenna Adapter" .
It plugs into the SIDE antenna port of your XM unit and you plug the antenna into that.
This URL MAY be a shortcut:
http://store.xmfanstore.com/directconnect.html
May 27, 2010 | Pioneer AirWave XM2Go Satellite Radio...
My tao xm2go will not turn on
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Nov 21, 2008 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
BRAND NEW BUT NO DISPLAY
I also had the white screen / blank screen problem on my Inno today.  I powered the unit off, removed it from the home cradle, and then popped out the battery for about 15 seconds and put it back in.  This fixed the problem.
Sep 13, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer xm2go power surge
I have the same problem with my XM2Go. The screen is blank. I ordered a replacement battery but it still doesn't work.
I could really use some help.
Vince
Mar 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
High Pitched whine when using line out with car power adapter
I was ready to mention the car's alternator but you say the noise is there if the ignition is on or off. What type voltage adapter are you using? It sounds as if it's the culprit. If it's an inverter I could understand the noise being generated. Have you tried earthing ALL the components involved? Earthing problems can cause some mighty weird things to happen.\ Are you sure nothing else in the car is switched on? eg. another radio or something with an inbuilt oscillator. Try running the power for the adapter straight from the battery and put a noise filter in line. Are you turning the engine off but leaving the ignition switched on? Doing this can cause a noise from the fuel pump. Oh and make sure the antenna is correctly earthed. Apart from that, I'm stumped BMW
Jul 17, 2006 | Tao XM2go Satellite Radio Receiver
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
194 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
