Question about Home Security
Gliderol door will go up by remote or control box button but will not go down at all.
Door goes up ok and stops at right place but will not come down again(ok in both directions manually)
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
Doorguy27
  • 30 Answers
SOURCE: 1.3HP CRAFTSMAN CHAMPION GARAGE DOOR OPENER-NEW IN 2004
Well sounds like its a pressure setting. you said you open the door by hand? Was it easy to do? Ask your self this can a 15 year old kid open it and close it? If so then it sounds like its a presure setting There should be two blue slots on your opener with numbers 1-9 says up and down force. Turn the up force towards the bigger number. Just a little bit. But before you do that as the other guy stated make sure that your cables and springs are working. Spring depending on your doors can be in three places but we going to assume you has the most common set up so look over the top of your door (with it closed) you should eb able to see a tube running across there. and somewhere in the in middle a set of spring look at the spring to make sure that you dont see any of the tube showing in the springs. Becare not to touch the spring as they are under a lot of stress.
Posted on Feb 10, 2009
SOURCE: Garage door won't close.
After replacing the worm gear and main drive gear on my Craftsman 1/2 HP garage door opener I found that my door moved about 4 inches stopped and reversed the same distance. I checked all the settings and everything seems OK. What fixed the problem was I released the two allen set screws on the end of the motor shaft and pulled tha motor shaft toward me. When I replaced the black plastic cap that looks like a pill cap top on the end of the shaft this corrected the depth setting that cap rotated through the RPM sensor. I set the limit settings (up and down) on the side of the opener and reset the force pots marked (KC) to mid range.
the door now works. I hope this helps. I also checked and eliminated the door sensors by putting a box in the beem this inhibited any movemnet at all, so I knew it wasn't the door sensors as there was at least 4 incheds of movement prior to the box and nothing with the box.
Posted on May 22, 2009
  • 3197 Answers
SOURCE: The garage door goes up, but will not go down. i push the opener
Make sure the door sensors are aligned properly. They must be pointed at one another and the small light on each one should be lit and not flickering.
Posted on Jun 13, 2009
  • 3197 Answers
SOURCE: Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
The LED flashing 3 times is the code for a bad wall control. You can easily verify this by removing the wire from terminal 1 on the rear of the motor unit. If your remote and keypad start working you will know the wall control is bad.
Posted on Aug 03, 2009
I have a genie pro 88 garage door opener push the button and it opens just fine traviels up to the limit switch and stops perfect. then push the button to go down and nota,
are the wires connected to the motor correct
for the limit switch there should be one wire ( normally black or neutral going to the center connection and the other wire ( red or active wires going to either of the other two terminals
that set up means that power is available to the limit switches and the return is the neutral wire
it works like this
on the up direction power is delivered to the motor by the controller box through a closed limit switch
when the up limit is circuit is broken the motor stops
the down button reverses the polarity of the motor in the controller box and so the motor runs in reverse through the the lower limit switch until that circuit is broken In the down action the upper limit switch circuit is completer but the control box has no power to it until the lower switch circuit is brokenis broken
the motor is dc voltage and to getting it to go up or down is done by the control box changing polarity for the motor power according to the button position pressed on the remote
Oct 28, 2016 | Genie Pro Screw Drive Garage Door Opener...
Door goes down but comes right back up
sensor in motor control needs sensitivity adjustment.
press the helpful button and chech link below
Force control Adjustments
Sep 15, 2015 | Craftsman Sears 139.53859 Compatible 390...
How to lower automatic gliderol gts 2000 garage door
check that the controls are not reversed by pressing the opposite button to the direction you want
Apr 05, 2015 | Garden
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I have 2 problems with my Craftsman Garage Door opener: 1. I have a 2 door-garage & 2 remote controls Both remote controls can open one garage door (since they were originally programmed). They...
I can't help you on programming.
If the door goes up as soon as it touches down, it is going too far down.
Locate the adjustment on the box on top. There should be four adjusters:
Door down amount more or less
Door up amount more or less
Force down more or less
Forch up more or less.
Turn the Door down amount toward the "LESS" or "-"
Let me know how you do.
Gary
May 31, 2011 | Garden
Control panel looks ok but dryer wont start
Sounds like an electronic problem on the timer circuit board.
Aug 11, 2009 | Siemens WT79020EU Electric Dryer
Garrage door opener ability to close the garrage door
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
231 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
