Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
E1000 blu screen
In Windows xp I get blu screen after 1 min from desktop... with linux same pc it works well. Already disinstalled all cisco software for windows. Original windows xp.
  • Cisco Master
  • 27,725 Answers
Windows !
BSOD Bluescreen of death can be caused by a number of things
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty.
Might be getting hot
Check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Then reseat the modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
Posted on May 16, 2013
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My linksys e1000 router works wirelessly with all my computers except my laptop which uses windows vista SP2, my network card is atheros ar5007, and my ISP is COX. I understand that the network driver is...
Most of the times you would be right when you say its a driver issue. :)
But there are certainly few steps that you can try as in -
a) Making an other third party program manage wireless on your XP SP2 machine
b) Tweaking the wireless channels to check if there is interference(this must have minimal impact as you already state that its working with everything else).
Try downloading a third part freeware to manage your wireless connections and uninstall the arheros client.
But before doing this try with windows client as well.
What is make and manufacturer of the XPSP2 machine??
Sam
Mar 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Need to put a password into a router that has been reset
If you install the cisco connect software to your computer, you should un install it first to have a better access on the web UI of the E1000,
you also need to reset the router, access UI, 192.168.1.1(default IP)
go to the wireless tab and configure the wireless setting,
if you have any problem with it call 1-800-326-7114
Feb 01, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Just purchased a Cisco Linksys E1000 Wireless-N Router. I am unable on my wireless laptop to connect to the internet. The Error I am getting from my computer is: The settings saved on this computer for the...
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
Hi! Bernie here, I have an Linksys E1000 wireless-n router. How could I adjust the interference on my phone (Vtech 2.4ghz) is there an adjustment to make on the router itself or do I have to buy another...
E1000 router is not a dual band router.
It works only on 2.4 GHZ wireless signal.
You can try changine the wireless channel on the router.
If you have installed the Cisco conect software on your computer, then open the Cisco connect software. Go to router settings. Click on advanced settings. It will open the setup page of the router. Go to wireless tab.
Set the configuration view to Manual.
change the channel to 11. See if that works.
If not then change the channel to 1 and check it.
Click Here for more information about the routers and network
Oct 15, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Can't get adapter to work, I get a error 211
it's no metter what router your using if your router is Wirless then it will work
what you do just run that linksys Software CD and folow the instrction
it will work
or go to goole site and type your quo. it will show you all the details
Apr 21, 2010 | Linksys Wireless-G WUSB54GC (DHWUSB54GC)
INF file txtsetup.sif is corrupt or missing status 14
LOL....I'm in a similar Windows boat that is sinking fast. Also using Ubuntu from a USB drive! Anywhoo....I got extra copy of XP I don't need anymore. Contact me if you're interested jh5637@gmail.com
Feb 12, 2010 | Sony VAIO Digital Studio PCV-RS420 PC...
Any alternative to xp's built in networking software?
Ok, what it sounds like you are wanting is a network file management system that is better than windows explorer.
If so, here are some alternatives that i found.
http://www.sofotex.com/download/File_Management/
has a list of free ones. not sure how good they are but may work.
www.tps.com/Products/NFM/nfm.shtm
www.m-files.com
A couple of commercial solutions, primarily business, but could work.
http://www.advexsoft.com/
These guys look like they have what you may need. Check out the advanced file manager.
Jun 25, 2009 | Microsoft Windows XP Professional
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
198 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
