Question about Bosch Washing Machines
Bosch classic 6 wae24164gb
Spin lights on but on button not lighting up so can't get the machine to start cycle
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
SOURCE: Bosch classic 6 1400 express washing machine - key
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Posted on Oct 19, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
How do I unlock the door of e43 Bosch washing machine error
E43 indicates a motor circuit error.
Lets try and reset the control board.
Switch the knob clockwise to off position. Now turn the knob clockwise to 6 O'Clock position and wait until the light starts flashing. Press and hold the spin button and while holding it turn the knob clockwise to 9 O'Clock position. Now release the spin button and switch the knob off. Tagged as: bosch
Dec 22, 2014 | Bosch Washing Machines
How do I reset the flashing rinse light on a bosch wae24060gb following a motor brushes change ? thanks.
Turn knob to 12 o'clock position turn to 6 o'clock position press an hold the spin button turn knob to 7 o'clock while still pressing the spin button let go of the spin button after 5 seconds turn the knob back to 12 o'clock
Dec 10, 2014 | Bosch Washing Machines
Why is my Bosch 1200 classic spin light flashing and won't machine won't spin
They aren't very complicated machines. Unplug and remove the back. Look for trapped clothing, broken belt or something that seems out of place. If it all looks normal you could have a bad circuit board (but if that's the case the machine should throw an error code) Cheap on EBay and easy to replace. Mine was $45 and took less than 10 minutes.
Jul 21, 2014 | Bosch Washing Machines
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 26, 2011 | Bosch Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
