Whirlpool HDW1011WG Fault codes
F11
  • 107 Answers
SOURCE: FAULT CODE F11
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
Posted on Mar 14, 2009
GodBlessU
  • 3513 Answers
SOURCE: f11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Posted on Jul 09, 2009
SOURCE: whirlpool duet washer
YA, I HAVE A PROBLEM SAME AS THE OTHERS. AND JUST LIKE THE MANUAL SAYS, YOU ARE SAYING TO CHECK EVERYTHING, BUT YOU WILL NOT TELL US HOW TO CHECK IT, WHAT IT IS SUPPOSE TO SOUND AND LOOK LIKE, WHAT IS NORMAL. SO WE CAN TELL WHAT IS WRONG WITH IT. I DON'T HAVE ALL THIS MONEY TO SPEND ON REPAIR MEN WHO DON'T KNOW WHAT THEY ARE DOING. SO WHAT SHOULD I DO. OH AND P.S. F-28 DOES SHOW UP ON THE WASHER SO IT REALLY IS A ERROR CODE.
Posted on Oct 16, 2009
  • 107 Answers
SOURCE: whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor
Control Unit (MCU) cannot be sent correctly.
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Posted on Nov 06, 2009
caroldon
  • 17130 Answers
SOURCE: Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Posted on Jul 06, 2012
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Code F1, does not stop filling, water pours out of soap tray
    Are you sure it's not an F/H error?
    The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
    If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
    Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
    Get appliance parts at http://parts.fixitnow.com
    Mar 13, 2011 | Washing Machines
    What is F11 code and how do I fix it?
    This one can be a bit tricky but is usually a bad connection or a loose coonection,shorted wire. Here is a link that should help F11 Fault code repair
    Mar 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
    Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
    Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Code F11 half way through cycle
    an f11 fault means that there is a problem with the circuit board.
    Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpoop AWM9000-WM1100 Displays fault code 11F? any ideas greatfull
    F11 on a Whirlpool AWM9000:
    Service manual says "Communication error between Control board and Motor control unit (MCU)".
    -Check control board
    -Check MCU
    -Check wiring to MCU
    Basically, there are two electronic boards in this machine- the one up the top that you use to operate the machine (control board), and a power board in the base of machine (MCU). F11 fault is indicated a communication error between these boards ie one of the boards may be faulty, or wiring connection between them may be faulty.
    It is impossible to know which electronic board may be at fault, as there is no way of testing them. Would advise calling service technician, but would advise you use an actual Whirlpool technician rather than a local service man, as Whirlpool tech has access to technical info required to solve your problem.
    Good luck !!(be wary- might pay to ask for an estimate of what repair might cost when booking service call, as some of the control boards can be expensive)
    Aug 11, 2009 | Whirlpool WFW9200S Front Load Washer
    ERROR F11 (Whirlpool Duet GHW9300)
    Hi there this is as it reads for your fault code F11
    Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    • Check the Drive system for any worn or failed components
    • Check MCU
    • Check CCU
    • Check Motor
    Feb 10, 2009 | Whirlpool GHW9300 Duet Washer
    FAULT CODE F11
    Feb 08, 2009 | Whirlpool AWM8143 Front Load Washer
    Fault code F11 on whirlpool AWM8143 6th sense mwashing machine
    got this from another site....
    Starting to see these fault codes pop up in these otherwise fine machines. The F/11 code is just a generic code generated when there’s a communications error between the two main control boards in the washer. These two boards are the motor control unit(MCU) and the central control unit(CCU).
    A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. If not, then you’re looking at spending some money on control boards. Yes, I said boards, plural. The really sucky part is that there’s no way to definitively and conclusively prove which board, the MCU or the CCU, is at fault so, unfortunately, that only leaves the parts changing monkey method: replace both boards,
    But, on a brighter note, the electronics are covered under warranty for 24 months. If your machine is older that this, then you’ll need to shell out some shekels
    tnx 4 using fixya,
    drcool
    Oct 05, 2008 | Whirlpool AWM8143 Front Load Washer
    Duet HT F11 fault code
    F11 is a communtication problem between the main control board and the motor control board . Check the wire harness connectors between those units and the motor.
    Jul 10, 2008 | Whirlpool Washing Machines
    Washing Machines Logo
    56 people viewed this question
    Top Washing Machines Experts
