Question about HP For Pavillion Dv2500 Dv6000 Dv9000 Ac Power Adapter Usa
What causes a processor for dv6000 to function properly
Black screen
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
Apr 09, 2014 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Tip
Recover HP Pavillion DV2000 + DV6000 + DV9000
Some HP Pavillion DV series have the issue of not starting up( screen is Black), lights are on, then it restarts over and over again.<br /><br />The solution is:<br /><br />Disassemble(open up) the Laptop with right tools.<br />When you get to remove the fan on top of the processor, you will see the processor and next to the processor an intergrated graphics card.<br /><br />Remove the processor.<br />Remove the Ram.<br /><br />What you do now is Get a hair blow dryer, set it to maximum hot air and blow 1 cm distance from graphics card for about 5 minutes.<br /><br />let it cool for 20 minutes.<br />Put back all components.<br /><br />start the POWER. wait and now your pc will show something like magic on screen..
on Nov 19, 2010 | Computers & Internet
Hp pavilion dv6000 black screen
This will be legit Bryan, but it may be something you do not wish to read.
The HP Pavilion dv2000, Pavilion dv6000, and Pavilion dv9000 series of Notebook PC's, share a common problem.
(There are other HP's, and Compaq's that fit this 'ailment' also)
The cooling for the graphics chipset is inadequate. Causes exactly what you are seeing, or lack thereof.
This is going to lengthy, advising you in advance. I feel all info is necessary to explain the problem.............
1) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The chipset used for graphics is a graphics chipset, or more properly referred to as the GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The graphics chipset is mounted to the motherboard with a BGA surface mount. Ball Grid Array.
To explain the BGA surface mount;
Compare to an older Intel Pentium 4 processor, that uses a Socket 478 processor socket.
The bottom of the processor has 478 contact pins.
The processor socket has matching socket holes,
http://en.wikipedia.org/wiki/Socket_478
With a BGA surface mount there are no contact pins, nor socket holes.
In place of the contact pins are Solder Balls.
In place of the socket holes, (And socket), are Copper Pads.
(The copper pads are gold plated)
The graphics chipset with it's Solder Balls on the bottom, is set on the motherboard lining up on matching Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action melts the solder balls, and solders the graphics chipset to the copper pads.
(Which in turn of course, solders the graphics chipset to the motherboard)
The cooling components for the laptop consists of a Cooling Tube, Heatsink, and Fan Assembly.
http://www.notebookparts.com/products/description.php?II=19424&cct_info=1'25720'5478761930'44237177'1095196157'b'6412929857'tc''g'''&cct_ver=3&cct_bk=434985-001
Click on the image of the thermal cooling assembly to enlarge.
The Cooling Tube is the slightly flattened curved copper pipe that you see.
It is sealed on both ends, and filled with Nitrogen.
Note the irregular shaped metal plate attached to it on the right, and smaller metal plate on the left, near the Fan Assembly.
The larger irregular shaped plateto the Right, sits on top of the Processor.
The smaller plate sits on top of the GPU. (Graphics chipset)
The Fan Assembly is the black curved fan blades you see, (Fan), and it's surrounding black D-shaped shroud.
In the front of the Fan Assembly is a rectangular finned Heatsink.
Heat is absorbed by the two metal plates sitting on top of the Processor, and graphics chipset.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat up to the Heatsink, and it radiates the heat away with it's thin fins.
The Fan Assembly helps carry heat away from the fins of the Heatsink.
The area of the small plate of metal sitting on the graphics chipset, is too small. Cannot properly keep the graphics chipset cooled.
(The Processor and the graphics chipset, are the two hardware components inside a computer, that give off the most heat)
With inadequate cooling the graphics chipset overheats.
Remember those Solder Balls, and when they melted they made a solder connection?
They start to partially melt. Soften up.
Then when the laptop is turned off they re-solidify.
This creates a Cold Solder Joint.
(Solder connection = solder joint)
A cold solder joint creates a bad contact. In this case, a bad graphics chipset to motherboard contact.
No graphics.
Can it be repaired? Sure. But if the cooling surface area for the graphics chipset is not increased, you will be right back to square 1 where you are now.
Without increasing the surface area it's just a temporary fix.
This is one tech's idea of how to permanently cure the problem.
I'm not advertising for him. I don't advertise for anybody. It's for reference.
I believe the best method is to use extra surface area as he has shown, but use a BGA Rework Station to properly resolder the graphics chipset, back to the motherboard.
I will say I read in one of this gentleman's videos, that he also believes the best method is to use a BGA Rework machine.
(He has three videos specifically dealing with the Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's)
http://www.youtube.com/watch?v=JEpnqhRYGLw
For additional questions please post in a Comment.
Regards,
joecoolvette
[ If you do wish to take this on Bryan, I can post a link to a free Service Manual, pictorial disassembly guide/s, and proper procedures for disassembling from me ]
Aug 28, 2012 | HEWLETT-PACKARD HP Pavilion dv6308nr -...
Difference between DV6000 Intel mothearbord and DV 6000 AMD motherboard
The DV6000 is a moniker for an entire series of laprop computers, each with a unique model number that has some variation the DV6XXX. Some will have Intel Core Duo, some Intel Celeron, some AMD Turion 64, and some AMD Mobile Sempron processors. Features, speed, and cost will vary appropriately with the Obviously the AMD and Intel boards are different and you cannot swap processors between boards. Here is a link to the HP Maintenance Manual for the DV6000 series laptops. It lists all the Mainboards used with the series and what processors go on them. It is useful for ordering replacement parts and gives instruction on disassembly and repair.
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
Oct 19, 2011 | HP Pavilion dv6000 Motherboard
A thin horizontal black line has appeared just below the centre of the screen on my hp pavilion dv6000 (running vista), there is no change when i gently press the screen, so i think the problem isnt with...
As the symptom you indicated above it is the problem with your LCD Panel. It is to be replaced to sort out this issue. To check and confirm the functionality of your Laptop motherboard plz check the Laptop with external display.
Nov 25, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Ds lite green power on, screens black
Sounds like the processor has gone on the mainboard.
Using r4 or similar card? if so these burn out the board sometimes.
Nov 24, 2009 | Nintendo DS Lite Console
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Soud doesn't work
i bet the wire is disconnected behind the speaker panel. take the screws out from under the battery and near your battery. pop the panel off and see if they are disconnected.
first read on how to take it off properly
if you are having a fan problem, black screen problem or any others.
Apr 06, 2009 | UltraLast For HP Pavilion DV6000 and 2000...
My hp pavilion dv6000 laptop does not turn on, the blue buttons light up, but the screen stays off
Try it without the rechargable battery connected sometimes the battery shorts and causes problems.
Do you have FN[function] keys at the left side. touch FN key with something else and see if screen comes back.Sometimes you can turn off the screen to send it to the back connected monitor.Connect (extra if you have) an external monitor to the back (vga) connector.If that shows, then you have to ""flutzz" with the FN(function) & F1-F12 keys
Nov 28, 2008 | Computers & Internet
HP For Pavillion Dv2500 Dv6000 Dv9000 Ac Power Adapter Usa Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
