Question about Freezers
Ice maker spits ice
My Siemens KA62DV40 fridge/freezer developed a problem about 18 months ago when the ice/water dispenser began to spit out ice/water onto the kitchen floor without warning, accompanied by various random beeps. The display panel would also 'lock' and change temperature by by itself. The problem was temporarily solved under warranty by the replacement of various control panels, but resurfaced about two months ago. Again, the problem was fixed temporarily by replacement of the dispenser unit and all the electronics boards. It started to go crazy again last week. Although I am still under warranty I'm wondering if I should ask them to replace the fridge itself as I've lost confidence it can be repaired. Does anyone have any idea if this is a common problem or what the source might be if not the electronics?
watugot
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
farfield
  • 462 Answers
SOURCE: Icemaker Waterline has Bacteria in it
This bacteria (for most of us) is not harmful. Ive never heard of anyone becoming sick from this stuff but I suppose someone might have an allergy. I see it in Ice Machines that are in restaurants all the time. It seems more prevalent in ones that do a lot of baking where yeast or Bread is used a lot like Bakeries Pizza and Hamburger fast foods...places.
Do you store a bread doe in your refrigerator? The air communicates with the freezer air. This is how its transferred. Clean the reddish stuff out again. Clean and wipe the outer containers and the walls and ceiling and under crisper in the refrigerator. Then if your going to store anything that you use with yeast or other types of activator that puts off CO2 (I E Baking soda or power?) double bag it in plastic bags. See if this solves your problem. If the stuff comes back it must be in your water supply. Are you on a treated water supply?
Hope this helps if so please rate me accordingly and good luck.
Posted on Mar 14, 2009
myrlex
  • 674 Answers
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Posted on Apr 04, 2010
SOURCE: I own a Thermador Freedom Collection 18 inch
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Posted on Jan 13, 2011
SOURCE: Frigidaire FKFH21F7HWA Freezer Control Panel Stuck at 0F
did you press and hold the freezer off symbol for three seconds
Posted on Jul 31, 2012
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
Oct 28, 2010 | Thermador Freezer FREEDOMĀ® T24ID80PLS
American fridge freezer siemens KA58NA50GB. Freezer not freezing
Apr 03, 2010 | Freezers
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Water does not seem to be flowing into ice maker.
Hi and I hope this will help. You can manually turn the timer and see if any water is dispensed into the ice cube tray . If no water is dispensed check if the valve is any good . A solenoid in the valve opens to allow water in to the ice maker. Sometimes timers stick too.
Jul 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Feb 10, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Freezers Logo
24 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
