Question about Motorola Mobility E815
Motorola E815 My motorola e815 when i plug it up it cuts off automatically. i tried cleaning t the ports with a toothpick and toothbrush but after that when i plugged it up, it did nothing!! PLEASE HELP ME OUT!!!!
    Problem Solver:
  • 14 Answers
Quit using car charger it tells it is full when u know its not i bet it shows full charge even though u know its not play around with a video or the web it will decrease battery indicator then hook it up let me know if that worked cuz thats what i do and it works
Posted on Sep 25, 2007
SOURCE:
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
Transfer my contacts from my Motorola e815
yes you can with the help of a usb data cable and motorola tools software, which you can download from motorola official website.
Jan 01, 2009 | Motorola Mobility E815
Motorola E815 phone number reset
J'AI UN MOTOROLA E815 ET J'AI OUBLIé MON LOCK CODE C'ETAIT PAS AVEC LES 4 DERNIERS CHIFFRE....AIDE MOI A RESET MON PORTABLE
Aug 30, 2008 | Motorola Mobility E815
Motorola E815
Leave it on charger on a while. And then turn on.
If no luck try to open and clean it inside.
If than is not enough phone have not contact with power.
That is usually for old phones just don't turning on.
Jul 24, 2008 | Motorola Mobility E815
Motorola e815
There is an article about someone who's screen went black. Click here
Apr 25, 2008 | Motorola Mobility E815
Motorola E815 Cellular
It sounds like one of the charging prong contact is lose inside.
to determine this turn off your phone and try to put it to charge.
if the phone powers up by it self. then that is the issue. and only someone with the right tools and knowledge can solder the contact/connector back the the main board.
If any questions please ask.
Thanks
Jan 03, 2008 | Motorola Mobility E815
Motorola E815 flashed to Cricket
you need to get that charging port repaired. www.fixphonenow.com can replace the charging port with a new on for $55.
Dec 06, 2007 | Motorola Mobility E815
Motorola E815 Display Screen Blank
Flex cable connected to the main board tend to get loose. You need cell technician to fix that problem.
Oct 22, 2007 | Motorola Mobility E815
Motorola E815 - Battery Charger
I had the same problem but for some reason was able to use one of those Energizer battery chargers but no others!! I took it to Verizon and they cleaned the pins. Try using a toothbrush to clean it. That worked for awile then stopped. I took it to them againa and since it was still under warranty, they gave me a new one!
Aug 21, 2007 | Motorola Mobility E815
PHONE TURNS OFF WHEN I CHARGE IT
Both of my e815's had this same problem. I was able to remidy it by taking a tooth pick and cleaning the contacts where the phone charger plugs into. Since I have done this neither one of my phones turns off when it is plugged it. Hope it works for you too!
Dec 10, 2006 | Motorola Mobility E815
Motorola Mobility E815 Logo
101 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
