LG lh-rh9691pa
Hi, The infra red sensor on my home theatre system has stopped responding to the remote control (the remote is fine) can the sensor be replaced?
SOURCE: LG home theatre system model LH-T1000
Hi I have the same tv. How is the video signal coming out of the dvd player and what is it plugged into on the tv. I travel for a living and coach my wife over the phone all the time.
Posted on Sep 17, 2007
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
  • 120 Answers
SOURCE: Sound to mute
i would suggest turning off the system, disconneting it from the outlet and plugging it back in, the should reset the settings, please post with what you try to do.
Thanks and i look forward to your post.
Posted on Nov 13, 2008
SOURCE: resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Posted on Jan 02, 2009
ravichetty
  • 158 Answers
SOURCE: I lost the remote control to my LG
CHECK WITH LG,THEY WILL SUPPLY 1
Posted on Aug 03, 2009
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
How do I get remote infared woking tried new batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 06, 2014 | LG Universal Remote Control For...
6710cdak14d remote control not working
If this is a new piece then even after a new set of batteries are put in the correct direction there is no action , the matter must be reported for warranty claim.
You can test the output of the remote on a phone camera as it wil show the IR- infra red- emission. If absent the fault is with the remote. If present then it is either a mismatch of frequency or a fault in the detection.
Dec 09, 2011 | LG LH-RH360SE Theater System
Remote does not respond to any function, tv is on and cannot change chanel or anything, frozen
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
using your cellphone camera again to test the infra red emmision of your TV. Aim the camera to the infra red of your TV.you must see at the screen of the camera that the infra red is illuminating.if not the infra red sensor of the TV is busted.
Jun 21, 2011 | Universal Remote Control MX-3000 LCD...
TV does not respond to remote commands. Remote has been verified to work as I am able to control my other LG TV. Tried a universal remote and still no response.
Then it is likely that the infra red receiver in the TV set is faulty - or possibly the 5 volt supply to the receiver.
The signals from the infra red receiver usually enter the system control integrated circuit. So if other control functions are working ok this is likely to be good.
It is possible that other equipment can block the remote signal - if another remote controller is stuck on [jammed down a crack in the sofa] or if you use energy saving lamps in the same room - they can produce high levels of infra red noise.
Please take time to rate my assistance - I hope it is useful.
Mar 22, 2008 | LG 42PC3DC 42 in. Plasma HDTV
Resetting the progressive scan mode on an LG lh-d2645 home theatre system
Jan 20, 2008 | LG LH-D6230 System
20 people viewed this question
 Grubhead
Grubhead
