Question about Mitsubishi WD-65735 Television
Sound While what TV/movie the volume of the TV speakers increase by itself. I can decease it with the remote, but increase itself again and again. Have to turn off the TV.
SOURCE: volume goes up on it's own
replace front switches
Posted on Jul 14, 2007
ronpar
  • 27 Answers
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Posted on Dec 06, 2007
  • 126 Answers
SOURCE: WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Posted on May 04, 2009
rulds2008
  • 3866 Answers
SOURCE: tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Posted on May 25, 2009
  • 80 Answers
SOURCE: WS-5551 only on/off button works, won't respond to remote at all
take off the speaker grill, you will see 2 wire plugs, turn the tv on, disconnect both plugs, if it now works with the remote then you need to replace all of the front switches, or leave them unplugged and use the remote, if this doesn't work, you have a bad dm board or signal module which could get very expensive.
Posted on Sep 15, 2009
The sound on all the movies on our tv is soft voice and loud music. How can I set the volume to be the same for both?
Some TV's have sound settings to empathies voice. If the TV has a centre speaker you can increase the sound output on that. That will make voices louder.
However many people do complain about loud music drowning out voices on TV. The problem is that movies were meant to be seen in cinemas and TV sound systems don't match up to that. If you can't find a solution consider a surround sound system as this will correct the sound problems on movies.
Nov 21, 2017 | The Audio Players & Recorders
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
Low volume on created DVD
Unlike ripping CDs, ripping DVDs poses many challenges for the average user.
Because you need to get audio and video and need to get them synced correctly problems with the final version frequently arise.
One common problem is that the volume is too low.
The solution might seem to be to simply turn up the speakers, but the sound of a low-volume movie cranked up can crackle or distort. Instead, you increase your DVD rip volume by changing it before you begin the rip process.
Increase DVD rip volume with iSofter DVD Rip (see Below).
http://www.dvd-tool.com/dvd-ripper/faq.html
With this program, a window called "Input Settings" allows you to control the volume before you begin. After the DVD is in the computer, you just use the "Volume" slider to increase the output volume. As of November 2010, the program costs $34.95.
Try Aimersoft DVD Ripper (see Below).
http://www.youtubetoipod.biz/software/aimersoft-dvd-ripper.html
After inserting the disc, you simply click "Load DVD" and wait for it to load
(this could take a few minutes).
The "Settings" button presents a volume slider similar to iSofter's.
Push it to the right to increase the output volume.
As of November 2010, the program costs $35.
The free dvd::rip program offers the most customizable settings for the advanced user
(see Below).
http://www.exit1.org/dvdrip/
Not only can you increase the output volume with a volume slider, you can also compress the sound as well.
This is useful for movies with both loud and quiet parts (such as action movies). It reduces the volume difference so you don't have to reach for the remote every five minutes.
Jun 27, 2013 | Corel 9900-65295-00 Pinnacle Studio 16...
Low volume on tv remotes up full tv freeview and booster still no good
Hello
If volume of the TV doesn't rise up as its volume is increased with remote control handset, and the volume indication bar runs full, the fault is with the TV itself. Either its speaker may be damaged or its audio output section has some trouble with it. Check its speaker first for damage. Connect an other good speaker in place, and you can check it by yourself. If the speaker is good, the audio output ciruit should be traced for fault.
Here you haven't given any details about your TV. Its Model number Brand Name etc: Eventhough you have given all these details to me, you must have a sound knoledge in electronics, and must have all tools with you to go forward with its inside circuit. OK.
Dec 13, 2011 | Televison & Video
Hey I lost the remote to the midiland mli 750 and I can't increase or decease the volume and the last volume I left it at was 25 and I can't even hear anything now is there a way to increase the volume...
you can try programable remnotes using the hometheater code entries , but more than likely you will need to buy a factory replacement remote.
http://www.remotecontrolscenter.com/
Nov 29, 2010 | MidiLand MLi 750 Computer Speakers
Low sound when converter connected
use converter volume button to increase the volume to the maximumthen use the tv remote to increase again up to the maximum. After to increase or decrease use only one remote.
Thank you for voting for me if itworks.
Jul 11, 2009 | Televison & Video
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Dec 18, 2008 | RCA RT2760 System
Philips 27PS55S/121 sound level decreases
Yes, the dynamic range on DVD's is enough to cause the high and low passages to be somewhat annoying but, sounds more like a movie theater. This kind of dynamic range showed up first on Beta HiFi and VHS HiFi VCR's because of thier range as well. If there is a feature in your audio menus on your TV such as "audio expansion, SRS, Wide mode, etc." turn it off and let the audio be processed without expansion of any kind as that will amplify your dynamic range alot more. The lock up issue could be something Philips is aware about and if under warranty contact them. Otherwise not much you can do except manke sure the voltage going to the TV is failry stable between 110 volts and 120 volts. Sometimes dramatic drops and or increases can cause lock up or confusion to the microprocessor in the TV.
Mar 25, 2007 | Philips 27PS55S 27" TV
Mitsubishi WD-65735 Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
