Question about Philips Sport Personal CD/MP3 Player
Phillips gogear GA 300060026
Ok to disconnect
5 Suggested Answers
SOURCE: gogear says ok to disconnect, but isn't charging, how do i make it charge?
hi , enter to the website of philips and download the software and new firmware select first you exact model, next quit batteries of your mp3/mp4 player and press the button (bent arrow) all the time until it detects and connect to the computer and run software and choose repair
Posted on Jul 15, 2009
SOURCE: I have a Phillips GoGear (Marietta GA 30006-0026)
I have a Phillips GoGear (Marietta GA 30006-0026) 2GB Mp3 player but i have lost the installation disc software. How do i go about downloading this?
Posted on Jan 27, 2011
  • 484 Answers
You can download it via this link:
http://download.p4c.philips.com/files/s/sa3125_37/sa3125_37_dfu_eng.pdf
gylacz
Posted on Mar 23, 2011
  • 484 Answers
SOURCE: Need to reset phillips gogear
Your player might hang up. Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software and repair device with it.
Contents will be removed by using the repair function.
How to do it is described on the manufacturer's web site here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&mid=Link_FAQs&view=aa12_view_partial.html&session=20110504030502_93.189.114.198&list=aa12_list_partial.html&slg=AEN&ctn=SA2627/37&dct=FAQ&refnr=0073454&faqview=1
Thanks.
gylacz
Posted on May 04, 2011
1994 Buick LaSabre won't shift out of park--brake lights OK, transmission OK after I disconnected shift cable on transmission--eingine/car runs fine--any ideas?
brake lights will be ok as there is a different wire from the switch for the interlock system just jumper the wires at the switch you should see 2 different wire connectors
Sep 18, 2014 | 1994 Buick LeSabre
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Crt standard hisense 54cm colour tv model tc2198L no powering fuse ok HOT ok.
Check the power supply.If you have no output from the power supply try to disconnect the power supply from the other circuits ( such as the IF,audio,video,horizontal,vertical,etc.If the voltage at the power supply comes up when you disconnect a particular circuit then that circuit is loading down the power supply and you would troubleshoot that circuit.If after disconnecting the other circuits and the power supply still shows zero,then you would troubleshoot the power supply.
Sep 14, 2013 | Televison & Video
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
Have never owned one so I want to make sure I am doing this stuff correctly. It didnt come with much of a guide.I plugged it in to my laptop to charge it then it automaticlly says ok to disconnect. when im...
If you are trying to charge it, and your computer says "OK to disconnect", then you can just ignore it. This is your computer telling you that disconnecting the device will not adversely affect the computer. If it's your MP3 player that is saying "OK to disconnect", I can only tell you that keeping it plugged into your computer via a USB cord will probably continue to charge it.
If you're unsure, disconnect it from the computer and see if there's an indicator for the amount of battery life remaining on your player.
I hope this helps.
Mar 06, 2011 | Audio Players & Recorders
This thing does not work always says ok to disconnect
When the mp3 player is connected to the computer, the only message it will generally give you is "OK to Disconnect" - this is normal.
Once you disconnect the mp3 player from the computer, then you can find your music, listen to music, etc.
If you are getting the "OK to Disconnect" message when the mp3 player is already disconnected from the computer:
Reset the player first.
If that fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Feb 28, 2009 | Philips SA3025/37 Flash MP3 Player
After charging go gear- ok to disconnect screen is locked up
Make sure the hold switch is not engaged
Reset the player
Run a Repair in the Philips Device Manager
Jan 16, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
OK to Disconnect
Fixed it myself! Reset by holding down Menu and centre button until soft reset complete. All working fine now.
Feb 21, 2006 | Apple iPod nano
Philips Sport Personal CD/MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
