Question about ACT Rapport 337 - CCTV Multifunction Tester
The LCD screen is blank , like there is now power. When I put it into setup mode--nothing happens . I just brought it in and removed the pics. onto my computer like I aways do with it. Then I wanted to change the date in setup mode and the screen is dark--nothing on it. When I put it into on--the front red light blinks like it should. The batteries are good and in correctly, so is the SD card. Why can't I see the LCD screen and use setup ? I have had it less then two years and it has worked perfect up till now . Please help me .
My LCD screen is blank on my Digital camera
Probably not...sounds like you did about all you can do.
Feb 17, 2013 | Cannon Cameras
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Display is gone, only pointer arrow shows
Try tapping the F8 key just after you power your machine up to see if you can boot to safe mode.
Mar 18, 2009 | Gateway MT6707 Notebook PC
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Screen is blank
Had the same thing:
Step 1 - remove the battery for about 60 minutes. There seems to be a little energy store in the unit and just taking out the battery, counting to 10, and reinstalling it does not work.
Step 2- Do a software update upgrade from the Logitech site. The new firmware level seems to have fixed the base problem.
If you just take the battery out and put it in, it does not work.
If you take the battery out and just hook it up to do a software upgrade, it does not work becuase the remote gets power from the USB commenction so it remains "hung"
The most disturbing thing about the whole event for me was the number of people that had the problem occur about 12 months and 1 day after purchase....ie when it was out of warranty!!!
Oct 20, 2007 | Logitech Harmony 890 LCD Remote Control
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Blank Screen..Will not power off
Have you checked your video source to ensure that this isn't a problem with your PC or whatever you're displaying on it? Try using a different display and see what happens. Try putting this LCD on a different PC and see what happens. If indeed it is this screen then it could be something as simple as a loose cable. Start simple and work from there.
Dec 27, 2006 | Proview XL775I (Silver) 17 in. Flat Panel...
ACT Rapport 337 - CCTV Multifunction Tester Logo
35 people viewed this question
Top ACT Home Security Experts
Lawrence Oravetz
Are you an ACT Home Security Expert? Answer questions, earn points and help others
