Question about Fisher and Paykel Dryers
Kelvinator dryer Hello Our F&P Kelvinator 505 ED starts ok then after a while stops and hums, I then have to spin the tumbler into the right position before it will start spinning again. This is getting worse and I have to repeat frequently.
  • Simon Averill May 19, 2013
    Still waiting for a solution?
    Master:
  • 563 Answers
Sounds like motor, capacitor, or inverter is going out.
Posted on May 19, 2013
IrishDruid
  • 2712 Answers
SOURCE: Dryer model DBXR463. Power is
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
  • 107 Answers
SOURCE: Kenmore Dryer 62602 Won't Start
Thermal fuse or motor relay. Make sure you have proper power at plug as well.
Posted on Mar 23, 2009
  • 221 Answers
SOURCE: when you press the start button the dryer hums and doesnt turn
check the fuse's and or breaker's to make sure on of them is not blown or tripped, check the belt to make sure it's not broken and check the tensioner, check to see if the drum spin's with little or no friction, if there are no blown or tripped fuse's and belt and tensionet are good the motor may be burned out.
Posted on Apr 18, 2009
  • 10865 Answers
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Posted on May 21, 2009
heatman101
  • 43501 Answers
SOURCE: model DVL223 GE dryer buzzes /
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
Kelvinator KLC 505
i have kelvinator klc505 washing machine and i need user manual.
Mar 09, 2014 | Washing Machines
Why kelvinator stop in india in 1999
I don't believe that fixya.com is responsible for kelvinator being stopped in India. You should try and locate the creators of kelvinator to see why they stopped it.
Oct 16, 2013 | Computers & Internet
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
Fisher & Paykel Kelvinator 2 Dryer starts and stops after 30 secs. What is wrong? How can we fix it? Thank you
You need to check the program controller unit. It is possible that the controller trips off due to some errors and so check the motor and the heater coils for higher currrent drain.
please check for tips on the link below:
http://www.espares.co.uk/advice/tumble-dryers/a/9
Jul 23, 2011 | Dryers
I brought this Kelvinator ED56 MULTI TEMP Auto Sensing dryer back in the year 2001and for some reason is that the tumbler is rotating at a very slow reveloutionary turn around and at times it just cease...
The most common cause for a clothes dryer drum to turn slowly or not start turning at all, is usually due to a faulty 'start capacitor'.
The capacitor stores electricity to help get everything turning from the stopped position. Once turning, less effort is required by the motor to keep everything turning.
Other components like a broken drive belt, burnt out electric motor, broken wire among other things etc also need to be considered.
Cheers
Apr 11, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
Kelvinator model N641n
I have a kelvinator refrigerator, top-mount type model # SKNT 16E.
220V, 1-phase, Defrost amps 1.9, Watts 575,
Gross/Liters 453/396
I have replaced new door gasket.
Freezer gasket is in very condition.
Compressor drawing 3.15amps.
  1. Question is Compressor is working 8 minutes and remains off for 3 minutes.This cycle is happening from some days.Thermostat and timers seem to be ok. Do i need to change Overload cut-out at the compressor or not....please suggest.
masood
masbimed@yahoo.com
Feb 18, 2009 | Refrigerators
Open Questions:
Dryers Logo
46 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
