Computers & Internet Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rundll32.exe not found
When i right click on my computer and go on properties tab then massege appeared as ''c:windowssystem32 undll32.exe'' application not found.
Anonymous
Level 3:
  • Master 412 Answers
  • Posted on Mar 16, 2009
Anonymous
Master
Level 3:
Answers
412
Questions
Helped
271872
Points
1322
This Error is cause due to virus.
Virus corrupt this file “rundll32.exe file”.
Use this Microsoft support link for more information:
http://support.microsoft.com/kb/832323
Anonymous
Level 3:
President:
  • Master 1,179 Answers
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422960
Points
3751
Insert your installation CD into the drive. Reboot and select the repair option. This should reinstall any missing files without losing any data on your hard drive. Hope this helps & please take a moment to rate this solution. Thanks.
2answers
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
I Have somehow lost the following file c:\windows\system32\r undll32.exe which is stopping me from getting into control panel etc
try this :
  1. Put the Windows XP CD ROM disk in the CD ROM drive.
  2. Click Start, and then click Run.
  3. Type expand X:\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
  4. Restart the computer.
Rundll32.exe is corrupt
http://www.jonmega.com/iceman/stuff/tutorials/replacing_sysfiles/ hth
In windows vista ultimate 64 bit. most of the items in my control panel will not open up. I get this message. c:\windowssystem32 undll32.exe file name or extension is to long. can you please help me. jim
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } hi
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
The rundll32.exe file operates by parsing the command line. The specified DLL is then loaded through the function LoadLibrary(). Afterwards, from the function , it gets the addresses through GetProcAddress(). The command line tail is passed when the is called. Next, the DLL is unloaded upon the return of . Finally, the rundll32.exe file exits.We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
if you have any question or any futher assistance you can get back to me on fixya for same
thanks
techbuddies
1helpful
2answers
C:\WINDOWS\system32\rundll32.exe
You could search for this file in c:\windows\servicepackfiles\i386, provided you have the service pack files copy in this folder.
One of my library files needed to run control panel is missing
If the system came with a cd for the keyboard, reinstall it. otherwise, reinstall the windows.
I have a rundll32.exe problem
Sounds like rundll32 got currupted by the virus, this is not uncommon. Perhaps you should locate a good copy. This site seems to have a good tutorial on how to do that:
http://ezinearticles.com/?How-to-Fix-Rundll32.exe?&id=913723
Good luck
Rundll32.exe
check immediately for any virus (especially w32).your rundll32.exe files in the /windows/system32 is missing or affected.try replacing the same from some other computer.or repair the windows using the CD
Grand Canyon Tech
Grand Canyon Tech
