D-Link AirPlus G DSL-G604T (790069265662) Wireless Router Logo
Posted on Mar 16, 2009
Can't connect to internet with router and wireless usb adapter
I have a AirPlus G router D-link 802.11g/2.4Ghz wireless which works well when my computer has built-in wireless connection. But now I have a desktop pc that doesn't have built-in wireless so I bought a wireless usb adapter. The usb adapter was installed successfully but I can't connect to the internet. What else should I do to get connection? Thanks.
  • melinda_reye Mar 16, 2009
    Hi, Vipin! The usb adapter manual says that it's compatible with 802.11 g/b devices. Does that mean it works in G mode?
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
11883
Points
26
Hi,,
Did you check whether the USG adapter can work in "G" mode, read the manual of the usb adapter and check whether it can operate in "G" mode since your router is a wirelss "G" model the devices which detectes signals should also work in :g" mode, And most of the inbuilt adaters are viable with a/b/g/N type routers, so please check the manual and let me know
Thanks,
Vipin Menon
  • Anonymous Mar 17, 2009
    Hi Melinda,
    If it says that it it G compatible you wont have any issues connecting to the wireless network, are you getting any error message while trying to connect??? are you able to go online with wired connection?? ie, with ethernet cable plugged in, If you need assistance , please find in my Gtalk, my ID: [email protected], i will be available after 7:30 CST, probably we can discuss on the isssue,
    Thanks
    Vipin Meon
Added a Belkin USB Wireless adapter to my desktop. Seems there is a wireless connection from USB to D Link but desktop can not see Internet.
1. Login to router first and verify that the router with the rj45 cable.
2. Go to the DOS window and then type "cmd" then type at the prompt "ipconfig /all". this will show the network connections but look at the wireless connect and the ip and MAC address.
3. Disconnect from the RJ45 ( Ethernet cord) then reboot the PC or laptop.
4. check laptop for IP address from router.
5. At the dos prompt do a ping >> www.yahoo.com
example: ping www.yahoo.com
1helpful
3answers
How to connect DSL internet to the second computer
You need an ethernet card, either hard wired or wireless to connect your computer to the DI-624.
Wi-fi card on Win98SE laptop not allowing internet to connect.
I really believe this is some kind of driver error. You must first remove the existing driver and then install the following driver.
http://download.cnet.com/D-Link-AirPlus-Xtreme-G-DWL-G650-Adapter/3000-2112_4-67890.html
If that doesn't work we're gonna have to try messing with the wireless router settings.
Help me
just installed the driver and the device then you get the wireless icon then go to it there view available network is showing just connect it and enjoy it
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Di 524 through speedstream 5200: wireless connects but no browse
try re-installing the driver for your USB adapter or create a new wireless network name.
You could also try to download the latest driver for your USB adapter. uninstall the old driver before installing the latest driver for your USB adapter.
2answers
Need help with connect a d-link,dl 624 router
You wireless router/access point can host several simultaneous connections to the internet. Just connect your laptop to the wireless network as you would from your desktop computer.
Hope this helped.
MO
D-Link DWL-G510 Connected but no packets
According to the user guide for your motorola broadband modem it doesnot support wirless capability , ie it can only hook your computers to the interenet using the wire. refer the following link
http://broadband.motorola.com/consumers/products/SB5101/downloads/SB5101_UG_EN.pdf
What is required , is additional pair of hardware ie.
1. Wireless Router(eg linksys or netgear)
or
2.Router/broadband modem(given by the ISP)
Your connection would then be configured through the wireless router , that would give you wireless capability.
Refer to the following link , it gives you the a step by step guide to setting up the wireless connection .
http://www.oreillynet.com/pub/a/wireless/2003/03/21/home_wifi.html
Best of luck .....
Thanks
mandeep
PS Do let me know if you need more assitance.
DI-524 connection problem
hi.
you need to configure the wireless encryption key on your desktop computer.logon to your router and configure wireless setting and configure your desktop with the same SSID / wep key and it shud connect.post back any errors
Wireless
ensure the modes are matched (ad-Hoc or infrastructure) and SSID and channels match.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
