Question about Sony PlayStation Portable (PSP) Console
Wireless won't connect.
My WLAN uses MAC address, and WEP. Also, my access point name does not broadcast. I manually put all the information into the psp, and I added the MAC addrss to my "allowed" list. The psp recognizes the connection, but won't connect to it. My laptop, and pc connect with no problem, and I checked and double-checked all the information that I put in the psp. How can I fix this?
    Novelist:
    Scholar:
  • 114 Answers
First and foremost check that you have WiFi switched on, it sounds so simple but you'd be surprised how often this is the problem. The WiFi switch is on the left-hand side as you look at the screen and needs to be in the up position to be on. A quick note about WiFi security; WEP is useless, even 128bit, freely available 'stumbling' software can crack a WEP encrypted network in as little as 20 seconds (depending on network activity). You need to use WPA or if you're OS supports it WPA2. Hiding you're SSID makes no difference as you're router still transmits and is therefor still visible, it just doesn't respond to access point requests. MAC address filtering is useless because once your network has been found all MAC addresses are visible. These days 'stumbling' software even automates the task of masking one MAC address over another. Although using as many layers of security as possible can help to keep nosy neighbours out WPA (and preferably WPA2) really is the only thing that will slow losers with nothing better to do down long enough for them to get bored.
Posted on Aug 11, 2007
  • Nicholas Wilson
    Nicholas Wilson Aug 12, 2007
    I take it from the 'Almost There' rating that at least 1 problem is resolved but others still exist.
    If you need anymore help and/or advice or your unsure about the WiFi security advice feel free to post back.
    Glad to be at least of some help. :-)
Can you connect several n300 routers
Connect a computer to one of the Belkin's "LAN" ports with an Ethernet cable.Open a Web browser and enter "192.168.2.1" into the address bar. Press "Enter."Click "Login," then click "Submit."Make a note of the WLAN MAC address on the Status page.Click "Wireless Bridging" under the "Wireless" category.Click to check the two boxes "Enable wireless bridging" and "Enable only specific access points to connect."Type the MAC address of the Belkin router and the MAC addresses of the other wireless routers or access points that are participating in the bridged WDS network. If using Belkin devices, repeat the previous steps to obtain the WLAN MAC addresses, otherwise refer to the owner's manual of the wireless device to find the WLAN MAC Address.Click "Apply Changes" to save the settings.
Nov 19, 2011 | Belkin Wireless Surf Router (F7D2301)
Tip
How to secure your wireless router
Most WLAN hardware has gotten easy enough to set up that many users simply plug it in and start using the network without giving much thought to security. Nevertheless, taking a few extra minutes to configure the security features of your linksys router wireless or access point is time well spent. Here are some of the things you can do to protect your wireless network:
1) Secure your linksys router wireless or access point administration interface linksys router wireless have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the linksys router wireless or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
2) Don't broadcast your SSIDlinksys router wireless automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
3)Enable WPA encryption instead of WEP802.11's WEP (Wired Equivalency Privacy) encryption has well-known weaknesses that make it relatively easy for a determined user with the right equipment to crack the encryption and access the wireless network. A better way to protect your WLAN is with WPA (Wi-Fi Protected Access). WPA provides much better protection and is also easier to use, since your password characters aren't limited to 0-9 and A-F as they are with WEP. WPA support is built into Windows XP (with the latest Service Pack) and virtually all modern wireless hardware and operating systems. A more recent version, WPA2, is found in newer hardware and provides even stronger encryption, but you'll probably need to download an XP patch in order to use it.
4) Remember that WEP is better than nothing If you find that some of your wireless devices only support WEP encryption (this is often the case with non-PC devices like media players, PDAs, and DVRs), avoid the temptation to skip encryption entirely because in spite of it's flaws, using WEP is still far superior to having no encryption at all. If you do use WEP, don't use an encryption key that's easy to guess like a string of the same or consecutive numbers. Also, although it can be a pain, WEP users should change encryption keys often-- preferably every week. See this page if you need help getting WEP to work.
5) Use MAC filtering for access control Unlike IP addresses, MAC addresses are unique to specific network adapters, so by turning on MAC filtering you can limit network access to only your systems (or those you know about). In order to use MAC filtering you need to find (and enter into the linksys router wireless or AP) the 12-character MAC address of every system that will connect to the network, so it can be inconvenient to set up, especially if you have a lot of wireless clients or if your clients change a lot. MAC addresses can be "spoofed" (imitated) by a knowledgable person, so while it's not a guarantee of security, it does add another hurdle for potential intruders to jump.
6) Reduce your WLAN transmitter powerYou won't find this feature on all wireless linksys router wireless and access points, but some allow you lower the power of your WLAN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WLAN.
7) Disable remote administrationlinksys router wireless have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the linksys router wireless. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off. (It's usually turned off by default, but it's always a good idea to check.)
source: http://www.linksysrouterwireless.com/article/Securing-your-wireless-network.php
on May 28, 2010 | Linksys Wireless-G Broadband Router
I need to secure my home wirless network
1) Secure your wireless router or access point administration interface
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
Most WLAN access points and routers automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
4) Reduce your WL-AN transmitter power
You won't find this feature on all wireless routers and access points, but some allow you lower the power of your WL-AN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WL-AN.
5) Disable remote administration
Most WL AN routers have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the router. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off
Thanks
Have great day
Sep 04, 2010 | Computers & Internet
I want to connect internet on my psp through a wireless access point but iam constantly recieving dns errors , what settings should be made on my psp and my access point? to solve the problem???
  1. Connect your router
  2. Open a brower window on your computer, preferably Internet explorer.
  3. Enter the IP address of the router (Ex: 192.168.1.1)
  4. Upon entering the IP address of the router in the browser it should direct you to your router box. If this does not happen then most likely your router box has been configured to a different IP address. To get this IP number run the set-up program.
  5. Now in the routher settings navigate within your router's settings dialog and locate "Wirless Settings"
  6. Check if you are assigned a SSID
  7. Check your region
  8. You should be on Channel 11. Sometimes the channel could different, in such situations make sure you are on the same channel.
  9. Check if "Allow Broadcast of Name (SSID)" is enabled
  10. Check if "Enable Wireless access point" is enabled
  11. Set authentication as "Open system". You will find this option under "Security Encryption (WEP)"
  12. Set strength of encryption as "Disabled"
  13. Now click on "Wireless Card Access List". You may need to provide your password again.
  14. Make sure "Turn on Access control" option is turned off "Disabled"
  15. You should now see your PSP listed. No, you dont see then on your psp, go to "system settings" and then to "system information". You will see MAC address, now make a note of this MAC address.
  16. Now in "Wireless Card Access List" select "Add". If you are not able to do this then enter the PSP's MAC address and click "Finish/Apply" when done.
  17. In WAN settings, verify that "Connect Automatically as required" is enabled
  18. In "LAN TCP/IP Settings" make note of all of the information included. You may need this later. You may not, but it's a good idea to take note of it now.
  19. Under "Router Status" make note of all the relevant information included here as well. You may or may not need it.
or click to view manuals.playstation.net
Aug 24, 2010 | Computers & Internet
I am trying to connect my Wii to the internet and error code 51330 comes up. What do i need to do
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  8. If you are still receiving this error code, please click here for assistance.
Dec 20, 2009 | Computers & Internet
Can somewone help me pls i need some help with my wii and seting it it alwAYS gives me an error code 51330 and some more help me pls thanks for your help???////
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
hope this will help..
May 24, 2009 | Dynex Enhanced-G Wireless Broadband Router
Router problems
Check with this tip.
Check if router is working on Net using a Lan cable to connect your PCs and check if you can browse from PC..
If Internet OK check if radio is enabled in your Belkin router.
Then check if your SSID broadcast is enabled in your router.
Check if Router and PCI Wlan adapter are on same WLAN standard A,B, G, or N and disable every security protocol (WEP or WPA)
Define a new SSID name and check if you see your Wlan on PC.
Restore your security as soon as connection established.
Jan 05, 2009 | Intel PRO/Wireless 5000 LAN Access Point...
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
