Question about EliteGroup Computers & Internet
If power on board then woking properly but working off after 20-25 mintues
  • EliteGroup Master
  • 5,660 Answers
20 to 24 minutes?
A) Plenty of time for the Processor (CPU) to overheat, and turn off. (BIOS turns it off)
1) Heatsink fins clogged with 'Gunk'?
(Dirt, dust, lint, hair, old socks {No}, banana peels {No)
2) Processor fan, and computer case fans dirty?
3) PROPERLY replace the Thermal Paste.
Thermal Paste looses it's thermal conductivity properties over time, so don't think you can just stir it around a little bit, and everything will be fine. Properly clean, and use fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
B) Check the Electrolytic Capacitors on the motherboard.
(IF used.
ECS motherboard?
Since they are budget motherboards, there is a good chance Radial Aluminum Electrolytic Capacitors are used, and very few, if none at all; Solid Polymer Capacitors)
http://capacitorlab.com/visible-failures/index.htm
Believe the problem to be more heat (Overheat) related, though.
[FOLLOW Anti-Static Procedures! ]
For additional questions please post in a Comment.
Also post the model number of the Elitegroup Computer System motherboard.
Post back in a Comment/Reply
Regards,
joecoolvette
Posted on May 06, 2013
LED TV has sound but no picture?
Sounds like it can be because of the faulty LED's. The LED is drawing over current for the power board that's why the fault arise again. There would be no fault in main board or the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 03, 2016 | Televison & Video
Omoron is not woking properly
Same problem on my Omron HEM-711. Manufactured in 2003, past the 5-yr warranty. Cust Suppt told me to replace unit. I opened the unit up and looked inside. Two very tight phillips screws, one on back panel, other in battery compartment. Case pries apart. LCD display looked intact, ribbon was undamaged. Unit appeared to work properly, just did not display correct reading, some of the liquid crystals in a few of the digits were not activating. I installed batteries with case still open, turned power on while pressing ribbon along edge of circuit board. Ribbon is manufactured with glue to circuit board, some of the leads come loose after several years due to manufacturing defect. In my case, pressing towards the bottom side corrected problem. You can see when it's working properly because all the display crystals light up simultaneously when unit is first powered up. I clamped down ribbon with two small paper clips insulated with a few bits of paper, works fine now, saved eighty bucks.
Apr 29, 2012 | Omron Health & Beauty
Hi my mother board is working but after 5 mintues it turn's off why its got 2.00gig of ram and anew power supply please help. Thank-You John
1. make sure that all motherboard fans are working especially the CPU fan. the motherboard shutsdown when it reaches a max temperature.
2. maybe your power supply is defective.
3. make sure that the CPU heatsink is properly seated in the processor
Jun 24, 2010 | Gigabyte GA-965P-DS3 (0818313003027)...
I have onida t v 21
Looks to be power supply problem. contact authorised service center for economical repairs.
Apr 29, 2010 | Televison & Video
Intel destop board D845GLVA motherboard is not woking
These board tend to go bad but there are a few things to look at before jumping to that conclusion.
first look for the cmos jumper and cross the pin 2 and 3, press and hold the power button. unplug the unit and do it again to drain the power. replace the cmos jumper to its original state. plug in the system and then try to boot. if it works great then it was just a bios error that needed to be cleared. If not move on.
next you will want to remove everything from the board except the CPU/heatsink and power supply. this includes the memory. if it turns on and you get a bunch of beeps your problem is memory related. Try 1 stick of memory or if you only had 1 try another one from another system or spare. if this solves it good else move on.
Reseat the processor. remove the heatsink, then unlatch the processor and press down on it then relatch it. place heatsink back on. leave the memory out of the system and try it.
if all of this fails there is a good chance the board is damaged. If you remove the CPU from the board and the board does not turn on, then usually the cpu is working which says bad board is the likely problem
Feb 11, 2010 | Intel Desktop Board D875PBZ (BOXD875PBZLK)...
Power failure after self clean cycle??
kill power eitther at plug or brreaker box,, wait 5 mintues turn back on if occrus again call for service possibly need a new control board this is common after power outages it blows the board out prob gonna be at least couple hundred dollars for a board maybe u want a new one ur call just giving ya a heads up k hope this helps bye bye
Jan 28, 2010 | Whirlpool GMC275PD Electric Double Oven
Washer won't start
Unplug the washer for a few mintues. If that doesn't work then you have a bad board in your washer. I am sorry to tell you that.
Dec 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Computer shuts down after 15 mintues or so. Replaced power supply, so thats not the problem. After 10 mintues computer might come back on. Sometimes the fans will come on and nothing else. It very...
It would be useful to have more complete info about your system. Model, OS, RAM, etc. However, there are a few generic possible problems.
The power supply receptacle on the motherboard may be out of spec ... it does not secure the power connector properly.
You may have a software or driver conflict. Use some thing like Belarc (free at belarc.com) to get a list of software and driver versions for your computer. Check with each manufacturer's website to ensure that your OS version and level is listed in their "system requirements". If not either remove the software or driver or update it.
Oct 22, 2009 | Compaq Presario 5000 PC Desktop
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
Engine won't run smooth for longer than 5-7 mintues
The throttle control board is not working corrctly
Mar 12, 2009 | Welding Tools
Computers & Internet Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
