Simpson washing machine error pu fl - Washing Machines
  • 4 Answers
SOURCE: Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
Posted on May 30, 2009
beltronic205
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
SOURCE: simpson washing machine encore 756
our simpson encore 756 flashes SP can anyone tell us what it means and how do we fix it thanks mark
Posted on Jun 18, 2010
torres No9
  • 27 Answers
SOURCE: my simpson eziset605 came up with an error pu now
PU is pump the drain pump probally has a hair clip or stone or summat interfearing with the **** impeller. if the pump doesnt function correct then it will not go into spin mode.
Posted on Jun 25, 2010
SOURCE: Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Posted on Jul 18, 2010
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
Hi,i have a Simpson EZI Sensor 6 kg top load it has PU error code, any one knows what this code reflects? Thank you in advance Mike
It means pump error. Water is slow to drain or not draining at all. May be a blockage or could be a faulty pump.
Dec 06, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
I hve a simpson aquapulse every time I do washing pu comes up can sme 1 plz tell me wat it means thx
PU code is the drain pump/\, This code can mean a bad pump, but most often there is some kind of restriction or blockage in the drain lines from the pump to the drain. Check for clogs/restrictions and clean them out and try again.
Dec 31, 2014 | Simpson Washing Machines
Does not drain, PU warning on display
Is there Bart Dryer? PU Indicates you have a blocked drain. This could be simple as by cleaning the screen filter. Or more involved. First check all your drainage hose(s) and the Bellows below the tub thru and thru the whole length. Be sure water can flow thru it. If it is still not draining then by Now you know if is the drainage pump is bad and needs to be replaced
Jul 26, 2014 | Simpson Washing Machines
Our simpson washing machine is not spoinning and the letters PU flash on the electronic display panel.
PU is pump fault. Usually caused by a blockage. Machine will not spin until all water is drained
Thank You
Sep 09, 2010 | Washing Machines
My simpson eziset605 came up with an error pu now it doesnt spin... i turned machine off and left it over night... tried again it washed ok but doesnt spin... the water drains out but the clothes are still...
May 21, 2010 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
